SOHC.co.uk Forums => CB500/550 => Topic started by: thomaspigeon on June 15, 2021, 12:51:02 AM
Title: Black smoke and hanging idle after a full rebuild
Post by: thomaspigeon on June 15, 2021, 12:51:02 AM
Hello everyone,
So I’m encountering some issues that starts to be beyond my league. I’m still quite inexperienced and this my very first full project. I’ll try to be as thorough as possible into my set up and problems as I know you’ll ask me a lot of questions if not  ;D ;D
Symptoms
- black smoke when accelerating
- Erratic idle (I have to play with the screw all the time to get it right)I can manage to keep it steady
- Low revs sputter and strong engine brake feeling
- mid/high revs quite ok but struggle to come back down
- engine run rougher when hot
Now about the bike
Model : CB550K3
Intake : Pods K&N (I bought this bike as an unfinished project and the air box was discarded already unfortunately!)
Exhaust : 4 into 2 with a short muffler
Carbs : 069A
Main jet : 110
Idle jet : 42
Needle : aftermarket (I’ve lost one OEM so can’t fit them but if anyone got a spare 273004 I’m happy to buy it)
Needle height : 3rd from top
Float height : 23mm
Mixing screw : 1.1/2 turns was looking like the best one
Top engine rebuilt with new pistons and rings, new valve seal, valves have been lapped
Ignition
I made a DIY LifePo4 battery that seems to run ok (though no BMS on it)
Electronic ignition from David Silver
Spark advanced system with the springs a bit retighened to make sure it comes back down.
Coils :  https://www.ebay.co.uk/itm/112789241229 (https://www.ebay.co.uk/itm/112789241229)
Spark plug caps : NGK 5K ohm
Spark plugs : NGK D7EA
Sliders don’t seem to stick and it looks like they are coming back down ok. I’ve set up the slide heights with a drill bit, the synchroniser was looking ok even though the pressure is very low. Spark plugs are very sooty but dry.
It’s a full rebuild with a lot of mods so I believe it might take me some time to get there but your help would be very appreciated. Let me know what you guys think!
Tom
Title: Re: Black smoke and hanging idle after a full rebuild
Post by: thomaspigeon on June 15, 2021, 01:01:34 AM
I forgot to mention, I tried to run it with a standard idle jet and the needle a bit higher but none of this helped, it actually was worst. Also the symptoms were quite the same.
What is hard to understand for me is how I have such a soot which means running rich while my idle is hanging which mean lean?
Post by: K2-K6 on June 15, 2021, 08:23:43 AM
Think you're quite close with assessment of mixture, black smoke being unburnt fuel in excess of what's needed.
As you say though,  slightly mixed message with hanging idle.
http://www.sohc.co.uk/index.php/topic,17769.0.html have you completed the first stage of method to sync in link? It's that bit that can easily get the throttle mechanism "hanging" slightly if not done accurately and would be my first call to examine.
The pattern needles are giving some very odd results in general site response and would be ideal to get that last one to remove that variable if at all possible.  In the meantime,  you could try setting them at top clip position (needle lowest) to get further assessment.
Post by: fogrider on June 15, 2021, 09:23:52 AM
I suggest you replace the main jet O rings. Even if it's just to eliminate that as a possible problem, it's cheap enough to try. You want 1.2 section by 4.2mm ID. That size is available. The lightest smear of petroleum jelly will help them push in. Don't twist them !!
Make sure they go on the end with the shortest end boss. (it's the deepest location for the O ring.).
Post by: thomaspigeon on June 15, 2021, 01:44:37 PM
Hey guys,
Thanks for you answers. @fogrider, the main jets are new with new o-rings so should be ok on that side.
@k2-k6 I haven’t done this method for syncing the carbs so will get through it probably this week end. Now dropping the needle might be a solution. So far the mixing screw doesn’t seem to do much. I remember with the stock 38 idle jet it was already doing the hanging idle and black smoke.
Also I’m wondering if the electronic ignition can fail at all. I could almost ride that way at some point but it wouldn’t be enjoyable as too erratic. It kind of misfire now as I think the plugs are getting too sooty.
Post by: deltarider on June 15, 2021, 02:22:21 PM
All K3s are prone to a hanging idle. The black smoke is intriguing however. Often it is a reduced air intake.
Post by: Bryanj on June 15, 2021, 03:17:37 PM
If its a Dyna ignition the US board reports a lot of faiures
Post by: royhall on June 15, 2021, 05:24:15 PM
I stopped reading at Pods K&N. They have got to go on a K3 the carbs don't like them at all. Search the internet for a correct airbox.
Post by: deltarider on June 15, 2021, 05:47:06 PM
But... his are 069A carbs...
Post by: royhall on June 15, 2021, 05:55:14 PM
Ah yes missed that sorry. So he's running F carbs on a K bike? They work better with pods but that said the internet is full of people trying to get a stable setup with pods fitted. I would still get rid of them and remove a known complication.
Post by: fogrider on June 15, 2021, 06:17:17 PM
Re the main jet O rings, I also installed new main jets that came fitted with new O rings. I was'nt  totally satisfied they were sealing fully , when removed and measured, they were 1x4 ( nominal) and , since O rings are sometimes subject to shrinkage in  manufacture, they were actually 0.9mm x4, which is a tenuous fit.
I figured 80p for 4 'O' rings was worth the effort.
Post by: McCabe-Thiele (Ted) on June 15, 2021, 06:42:40 PM
Interesting comment about strong engine braking. Not sure if you have had a rebore or how many miles you have covered since the build but I personally would not be altering too much until the engine has at least partially run in.
Post by: K2-K6 on June 15, 2021, 07:23:03 PM
Shutting the throttle with it running that rich will give alot of engine braking as it's probably close to stalling like that.
Post by: thomaspigeon on June 15, 2021, 08:18:29 PM
@bryanj here are the electronic ignition that I’m running (not a Dyna S) https://www.davidsilverspares.co.uk/CB550K3/part_192275/ (https://www.davidsilverspares.co.uk/CB550K3/part_192275/)
I still have the points somewhere so I might give it a go.
I probably have some O rings kicking around so I can change those
I can’t try anything until this week end but yes definitely a hanging idle and black smoke is a mixed message. Now I’ve read somewhere that you can solve this by dropping the needles so can be worth the try.
Also I know it’s a complication but I can’t put the air box back as the previous owner discarded the air box
Post by: thomaspigeon on June 15, 2021, 08:23:45 PM
I mean he removed the brackets on the frame
Post by: K2-K6 on June 16, 2021, 10:24:42 AM
Certainly the original airbox is preferred and particularly good on these Honda, but I believe the general view out on the big wide interwebs starts with false assumption (well aren't many assumptions false?  ;D ) in how they approach running alternative intake.
That assumption seems to be grounded in "well it's now getting more air so it'll need more fuel" and partly promoted by filter manufacturers claim in the improvement their offerings deliver.
For a std engine that's not true, but more that the change alters the carefully designed vacuum gradient that honda made and jetted the carbs for.
Essentially,  and for the same engine speed, the carburettor now enacts less vacuum and so draws less fuel from float chamber at the same engine demand. It's that which makes it run lean.
Inevitably you'll have to respond with some tailoring of fuelling to bring it back to a normal level, you'll have to add more fuel to less vacuum to bring that change.  Making a jet larger just allows that vacuum to pull more fuel through that jet as it meets less resistance.
Knowing what to add at which point is the part that's difficult to determine.
For a start point it's worth leaving the main jet alone and standard, but lifting the needle one notch.
Going up one size on idle jet,  but starting with airscrew out 1/4 turn from specification.
Worthwhile using at least NGK 8 grade plug to help avoid overheating the plug tip.
Note;- increasing BOTH idle jet size and main jet will usually make it too rich at large throttle opening as the two changes are accumulated, the idle jet adds volume right across all carb opening.
To the OP,  which size idle jet have you used?
Post by: thomaspigeon on June 16, 2021, 03:10:46 PM
Thanks for taking the time to explain this @K2-K6
I think restarting to square  one is probably a good thing. Now I’d really like to buy an OEM needle as the aftermarket ones at troublesome apparently.
My current jetting is :
Main 110
Idle 42
Clip on the 3rd position from top
I still have the original ones so I can do this.
I’ve got D7 grades plugs so that should be ok on that side.
One last question, I didn’t apply any oil on the K&N pods. I believe applying so K&N pod oil might increase the resistance so I’ll probably do this too.
Post by: fogrider on June 16, 2021, 04:29:19 PM
After all the tests and trials I've done to get my 550 fuelling right, with foam filter , paper filter and no filter at all, it looks to me like all you're settings are way too rich.
 I think you have the 069a's like mine, if so, start again with 38 idle, needle in 2nd from top clip and 98 or 100 mains with air screw 1.1/2 out, and take it from there.
The idle jet seems  especially important, I've just discovered my idle settings were  badly effecting the whole system, after the knack***d float needles and valves were changed, float heights set, richness from the idle system had me chasing ghosts. Idle jet checks out as  41 ( marked 38 though) and seems to be way too big. I'm going to try some 35's just to prove a point.
All part of the fun.
Post by: K2-K6 on June 16, 2021, 05:39:17 PM
"After all the tests and trials I've done to get my 550 fuelling right, with foam filter , paper filter and no filter at all, it looks to me like all you're settings are way too rich."
As you find, there's delicate balance and shift around the lower end carburation, and more complex with the K&N type pods.
They effectively add another layer of pain with both the bell mouths and still air box removed.
I'd still start with just the idle sized up along with the setting changes as a first look as it'll give us a picture of response and something to go on.
Post by: robvangulik on June 17, 2021, 12:05:40 AM
Does the black smoke persist with the k&n's removed?
Post by: thomaspigeon on June 17, 2021, 12:14:49 AM
@robvangulik I didn’t try this yet.
@k2-k6 and @fogrider I started to reset the carbs after work as all this news got me really excited to try. I didn’t have the time to finish but hopefully I won’t get out of work tomorrow.
I’ll probably try a idle jet at 40 just to see
Keep you updated
Post by: thomaspigeon on June 17, 2021, 11:08:50 PM
Hey guys,
So good news, no more smoke and no more hanging idle! Now the midrange were weak so I lifted the needle to 3rd position from top. This fixed the problem quite well.
Low revs are struggling to pick up so I believe I’ll need to play with the mixing screw (current idle jet at 40 and I’m still 1.5 turn out). But will do this tomorrow evening if I have the time.
Also from 3/4 to full throttle its really not picking up. I suppose I’ll need to change the main jet to 100 to try maybe 105 but I don’t want to cut corners.
It’s the first time I started to get some sensations on the bike and felt like it’s actually running! I could almost take it out like this. But I’ll take the time to have it running a bit better before I go for an actual ride.
Thanks a lot for your help @k2-k6 and @fogrider! Keep you updated
Post by: K2-K6 on June 19, 2021, 10:04:50 AM
Good progress,  and now a clear picture of individual elements to work on.
Yes to change the initial pickup in adjustment of airscrew inwards to then try like that. If you found that you end up below about 3/4 turn out from closed it would indicate that a small step up in size of idle jet would be ok. See where you get to first with this one though, and it will usually look different to with a std airbox so a little unconventional setup is to be expected in making it work.
Something that seems to help is to use R Plugs as well as R caps and set plug gaps to their absolute minimum in manual specification.  It's beneficial in weaker mixture running and helps prevent the engine dropping into a flat spot at mixture margin. If you want to try that, then use NGK R 8 rated plug. It also (#8) reduces the risk of the plug tip getting too hot and being compromised.
Post by: deltarider on June 19, 2021, 10:49:03 AM
... and set plug gaps to their absolute minimum in manual specification...
This ^!!
Recently I have bought a set of 4 DR7EA plugs (I run silicone non resistor caps). When checked, I was glad to see, they were already set to the minimum by NGK: 0,6mm. Whereas the D7EA plugs, that I've bought years ago and that are still new in their boxes (for if I ever return to resistor caps), are gapped a little wider. Coincidence?
Post by: thomaspigeon on June 21, 2021, 11:01:43 PM
hey,
So I went from #38 idle jet to #42 as the idle was hanging a bit and I couldn't close more the mixing screw.
I didn't have the time to play too much with it but for now it looks promising. At 1.5 turn out it's running a bit lean/ hanging idle and at 1 turn I have some black smoke but no hanging. So the right balance is in between this 2.
It feels like full throttle is not very powerful, I'm still at #100 on the main jet. But I think 105 is a bit too much as I already have some black smoke. I never had a running CB550 in the past so I don't know how powerful those engines should be.
I might have some DR8EA plugs kicking around but no R plug caps. @deltarider are you saying that I can run regular caps with R plugs?
Also last thing, engine seems a bit noisy and also jumpy when decelerating - accelerating. Like the cam chain is a bit loose. My tensioner screw doesn't seem to function properly (it doesn't do the spring return effect). Some people are doing the cam chain tensioning while the engine is running, is that a good idea?
Thanks for your help, it's getting there!
Post by: deltarider on June 22, 2021, 07:16:48 AM
... I might have some DR8EA plugs kicking around but no R plug caps. @deltarider are you saying that I can run regular caps with R plugs? ...
Sure you can. So far I have seen no proof of a positive effect by adding more resistance than the 5kΩ that either a R plug or a resistor cap provides. The discussion pops up every now and then in the international forum, but I have yet to see a falsifiable result, meaning it can be reproduced. In my opinion the plug gap - more or less wide - is far more determining spark duration.
Quote
... Some people are doing the cam chain tensioning while the engine is running, is that a good idea?...
I have to do it like that, as my tensioner bolt is not properly functioning, but I can not recommend it, unless you have to. Do not expect to SEE the bolt turning when the lock nut is loosened. It moves just a fraction! Also do not expect too much result of adjusting the tensioner. Often the culprit is in the ignition or carbs that are not balanced well.
CB500/550 owners are advised to have a look at this video shot by René van Maanen of Honda4.nl. It gives you an idea how the tensioner works and why you will not even see the bolt turn when you loosen the locknut to let it adjust. It will move just a fraction. Also do not expect a wonderful humming engine after adjustment. You will always hear the camchain.
Mind you, the vid does NOT show how to perform the adjustment, it only demonstrates what goes on.To adjust, either do it by the book or like Bryan suggests.
I do NOT recommend to do it with a running engine like Honda's Owner's Manual CB500K3-CB550K3 suggests. I don't know why it is there. Could have been an error in editing by copy and paste.
https://www.youtube.com/watch?v=8qJc6e5pa8M
Courtesy Renë van Maanen - Honda4.nl
Post by: thomaspigeon on July 12, 2021, 11:09:23 PM
Hello everyone,
After countless carbs disassembly and reassembly. I start to see the light at the end of the tunnel.
I'll try to get through the process briefly :
1) I first went for pilot #42, main #98, 3rd clip position
2) Soot and smoke was building up, idle was hanging when up in the revs
3) Changed the spark plugs for DR8EA but it wasn't firing properly and flooding so back to the D7EA
3) Went for new O-ring (thanks Nurse Julie and Fogrider) for the mains and put back OEM needles and emulsion tubes
4) Very little difference but slight improvement in the riding qualty though still soot and black smoke and hanging idle
5) I measured how much petrol were in the bowl, between 50ml and 60ml (is that too much?)
6) I went for pilot #38, main #110 (I don't have any #105), 3rd clip position
7) Somehow some carbs started to leak petrol from the overflow massively and flood the pods (and so the engine)... taken them out to fix this...
7) NO MORE SMOKE! NO MORE HANGING IDLE!  ;D
It really starts to run well BUT it's struggle to take off when hot and sometimes stalls, I really have to rev it to take off. Once rolling it's fine. Basically low revs are bogging. It's idling fine though. If I wait at a red light and try to go it's really boggy like it's building up. I tried to play with the mixing screw but very little difference on this problem. I struggle to put it in Neutral so I guess carburetion is not quite there, yet!
Now here are my different thoughts :
1) Some carbs are still leaking very slightly from the overflow (like a drop or so but only when riding) and I kind of find a bit of petrol under some pods, if the level is too high in the bowl, could it flood the carbs? I don't have any smoke though but I tested late this evening maybe I didn't see it.
2) Clip position is too high so it's running too rich when accelerating
3) I need to go for #40 pilot jet
4) Get the DR8EA back on to see if it helps to fix this
Let me know what your thoughts are on this one,
Tom
Post by: fogrider on July 13, 2021, 09:50:22 AM
Tom, I had confusing symptoms on mine, it always seemed really weak just off idle, gasping/bogging, but never any black smoke.  I finally found the idle circuit was over-feeding the full range, even though it ticked over OK. Idle jets measured as 41.
Long story short, it needed SMALLER idle jets, contrary to the symptoms. 35's have cured it , completely. Got 'em in a cheap aftermarket kit for a CB350.
It seems  illogical, but it worked (for me anyway).
I think it was the American side of these forums where I read two owners with EXACTLY the same issues. After trying everything, it looked like they finally gave up and flogged their bikes, I reckon the illogical step of smaller idles would have made them happy owners too.
Good to see you don't give up easily.
Post by: Trigger on July 13, 2021, 12:24:29 PM
I have found over the years it is very hard to advise on carbs as, they all have different worn out parts. And all have different engine's in different states. You can be chasing a carb problem for years if one head valve is leaking  ;)
Post by: fogrider on July 13, 2021, 02:00:03 PM
Quite right, the older the bike, the greater the mileage done, messed with by previous owners etc, plus going by previous experience can be misleading too. Until I put the Lambda sensor in I was convinced there was weakness causing the problem , the symptoms seemed pretty clear, I wasted a lot of time trying to resolve weakness.
The Lambda showed the reality, or I would be still chasing it now !
She was badly neglected so lots of things to resolve all at once which did'nt help.
Keep at it Tom, it's all part of the fun......
Post by: thomaspigeon on July 13, 2021, 04:17:26 PM
Thanks for your reply guys.
I doubt any problem is coming from the engine as I rebuilt it and done all the test to make sure everything was working ok.
Now changing for #35 as a pilot could be a good idea. But I’m running pods which si seems very small, though those jets are #38 and might have worn out. That can be considered.
Also lambda sensors are definitely something I might start to consider too
Tom
Post by: fogrider on July 13, 2021, 05:21:54 PM
My bike lent itself to fitting a Lambda sender as it is the 4into1 style exhaust with an aftermarket silencer - that fixes to the end of the 4into1 with an adaptor sleeve. I simply brazed  the sender boss into that sleeve.
I already had the Lambda system too, which helps, so I did'nt have to pay for a couple of dyno runs.
It's not a cheap or easy route to take, but if all else fails, it's a valuable extra tool to use, especially if you have other vehicles and can make more use of it in the future. I've used it on 4 different vehicles now, with good effect.
I'm not sure I'd have bought it just to sort the CB550.
Personal choice .
Post by: thomaspigeon on July 13, 2021, 11:59:12 PM
I've ordered a repair kit for the CB350F carburettors. I rode it today and their is still a bit of smoke when hot so I guess I have to reduce some jet size somewhere!
It will arrive next week. Hopefully that will do the job. I'll keep you updated
Post by: Trigger on July 14, 2021, 08:53:26 AM
Black smoke is nearly always the piston to bore clearance, worn oil rings, valve guilds or seals  ;)
Post by: fogrider on July 14, 2021, 09:06:02 AM
So when a float punctures, or an air filter is clogged, the choke sticks on, dirt on a float needle , a main jet falls out etc etc, that gives blue smoke ?
Or maybe I'm colour blind !
Post by: Trigger on July 14, 2021, 11:08:39 AM
Why would a main jet fall out, it is held in by the spring and compressed by the float bowl  ;)
Once upon a time i built a 550 motor,  the bores were with in spec so, i just put new rings in with a light X hatch. The carbs were fully rebuilt but, the bike smelt very rich and had a small amount of black smoke. After 3000 miles and forgot how many times i had the carbs off, i decided to strip the engine back down again and check the head and barrels. Everything was with in spec and as i had a set of 0.50 pistons and bores sitting on the shelf, i decided to fit them.
Now that bike has never smelt rich or given any black smoke since and Julie is still knocking up the mileage on it  ;)
A bike is many components and not just a bank of carbs  ::)
Post by: thomaspigeon on July 14, 2021, 11:19:45 AM
So this CB has been rebored at +0.5mm with new pistons fitted, new valve seals, valve have been  lapped too. I’ve done a compression check and it has 145psi (everything is new I assume the compression will raise after the run-in period).
Hard to believe I have a leak somewhere. I had the valve play inspected by a specialist, he said it was ok.  Unless I forgot some lapping paste on a valve (I also cleaned everything with cotton buds and petrol) I doubt it’s possible I have any leak.
Post by: Trigger on July 14, 2021, 12:01:01 PM
145PSI is too low if you have had the top end done.  Running pods will never help you as, these old girls don't like them  ;)
Post by: royhall on July 14, 2021, 12:18:47 PM
Agree with Trig. Hands up anyone who has got these bikes perfect with pods fitted. They usually end up as some sort of compromise.
Post by: hairygit on July 14, 2021, 12:21:49 PM
Running pods, especially some of the ones I've seen have appalling filtration, basically they can knacker a rebuilt motor in a 1,000 miles as abrasive dust, grit etc gets dragged straight into the motor. All very well assuming that because racers use them they must be a good bet, but most engines are rebuilt after every race!
Sent from my JNY-LX1 using Tapatalk
Post by: thomaspigeon on July 14, 2021, 12:56:26 PM
So I also forgot to mention. My compression tester is a rubbish one. It doesn’t have a valve on the spark plug side  but on the gauge side. Meaning my compression reading should be a way higher with a proper tool.
Now I’ve done other engine rebuilds with this tool. And I always had a low reading with it. I never bothered changing my tester as the engines were running strong all the time after my rebuild.
About the pods. As I said previously, the previous owner discarded the airbox, bracket included so I didn’t have the choice really. I’m running K&N pods with oil on them. I run K&N filter on my africa twin and it’s spotless. I agree that velocity stack will knacker any engines. But pods are not supposed to if they are from a good brand
Post by: thomaspigeon on July 14, 2021, 01:02:49 PM
Now I know pods are a compromise and I’m ready to be wait until I get the right balance. I’m sure I’ll get there. It’s just a question of time
Post by: fogrider on July 21, 2021, 05:37:37 PM
Thomas, something to check while the carbs are in bits: mine was way over rich the full range, one of the things that seemed to make a massive difference was the seatings for the emulsion tubes. I was a bit slow spotting this , but a minute examination of the emulsion tube alloy turret showed that there was ally gunge on the seating face, also minutely on the brass seating face of the tube. (needle jet end ). It took a multi-facet milling cutter (6mm) turned carefully with fingers only, to clean the ally seats  up. Also, the turret had minor surface faults inside where the main jet O ring sat that needed carefully polishing out.
In addition, I felt that the main jets were not fully in despite being pressed to where they felt "right". I put a main jet in without its O ring and clocked the depth it sat. I found it needed a steady push to make the jets sit fully home. I'm certain that all the above  cured some fuel leakage past the seating face in the depths of the alloy turret.
Can't prove it, but I think its an essential thing to make sure is spot on.
