SOHC.co.uk Forums => Recommended Sources for Parts and Services => Topic started by: McCabe-Thiele (Ted) on June 23, 2021, 05:01:19 PM
Title: New e-bay listing for SS cam cover bolts on Honda 400/4
Post by: McCabe-Thiele (Ted) on June 23, 2021, 05:01:19 PM
Not for the purists......
https://www.ebay.co.uk/itm/255027081198?_trkparms=ispr%3D1&hash=item3b60cc6fee:g:2sQAAOSwYj9g00Bh&amdata=enc%3AAQAGAAACoPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSg3Ye8yTWgOW7pmE1t838dpxV3QyaN2fW1XECwPJH2vX9VErGjoZIKdLI%252BnUT1L4UxwJfUZLlE4ke8iQdiF2uwELwMcPygLn%252BXPsOC4QGKBYBufhr%252FYn3d%252FfIhRugDpdBCYpjCjsUgHhM2GwUR6G1RFpkwXkg6mGPNoNUdL%252Fg4lnjeS5Id1oJOK0o8LmsUIGTVw82inMdNflqBdNVHQGSuV%252BlYt5SlOLnu8Dn%252BqSTP78%252F0vPvMHwGG1X%252FzCc47NMRF9YjvIC8N8YwsvuuLC3VUsZWeO6e8bmZ8F8bAJYwzUxi8KlqJ7XhhM2kLbFUNYhSBVxXGxdz5v19wNtb5FWkT59Hovs3UqtPVgRy%252FtzPW7lNHJqHdHm3KbBS%252BekOSqPsQHyQ6AgRABCm%252FHVGOEG6cSmYWHDNfHdoDdDY6z%252FWkggklbwTyTwcIH9MNxx05wrlCY8bK6JMgFwc6FohA2EwekKL%252FaDgG5TxEB36Ahv%252F1v7kiNwCcmttgV6AhGk4ohcx4zhWS5J91tRtapudgk0elckUjVIkvt5yYDGbdi%252BsBr30KfLHHe6xD%252BmqFVxC28Ieg1Nz%252BcrL5xruNu%252B1k6JhwdCTFc7XjbToQzuE4bZmq6DgL9PaovSODniou5x0xQIrXqXRye1uaGpBzQx3TosmhMFIzYuqisycc1XQVCHIgpSaT67U1H12WOXlA9o%252FMUmK9cpuXQX8ku5jET1B%252B%252F55x1UdGrNeLvzZRQdV0ShtL10%252FP6k%252F31HwBiGvyzHowWLLzIOyXEeCdxdw566HKZr79U5TUDBhYX0fvTpt%252BCImD9W2mMQ%252BpM%252FjvH67e3QTnuXECBIw53JDbYaJrlMmhrWAVw%253D%253D%7Campid%3APL_CLK%7Cclp%3A2334524
Title: Re: New e-bay listing for SS cam cover bolts on Honda 400/4
Post by: royhall on June 24, 2021, 04:40:19 PM
No, they are just cheap stainless bolts readily available on eBay. At least go to Middletons website and buy some polished ones.
Post by: Nurse Julie on June 24, 2021, 05:14:09 PM
We have bought quite a few bits direct from Tina. Not SS ones but she can supply some real odd ball lengths cut to our requirements.
Post by: McCabe-Thiele (Ted) on June 24, 2021, 06:13:49 PM
My crancase set from them were polished. Then again I guess there is polished and dazling !
It appears the bolts are also not fully threaded hopefully  the right length for the job.
Post by: hairygit on June 24, 2021, 06:20:38 PM
Using the correct terminology, a bolt has an unthreaded portion, if it is threaded it's full length it is a setscrew
Sent from my JNY-LX1 using Tapatalk
Post by: McCabe-Thiele (Ted) on June 25, 2021, 09:31:21 AM
I live and learn thanks for the correct terminology oh hairy one that's the opposite to what I thought somehow.
In my head setscrew sounds more precise so ought to have a shoulder or unthreaded section.
Sadly I'm still firmly in the Farhenheit zone even though I used SI units at Uni - I still can't get used to Centigrade for the weather either.
I am clearly either a Ludite or mentally resistant to change there is no hope for me I'm a lost cause. lol
Post by: Bryanj on June 25, 2021, 10:13:52 AM
Me 3 but then we all buy timber as 3mtr of 4x2 inch!!
Post by: royhall on June 25, 2021, 10:16:27 AM
I bought a piece of 3/4 ply yesterday and had it cut to 24' * 608mm. No hope for me either, the woodshed guy just rolled his eyes.
Post by: Bryanj on June 25, 2021, 10:26:46 AM
Carefull with cam cover bolts as some need to be button head or you cant get the tappet caps off
Post by: McCabe-Thiele (Ted) on June 25, 2021, 10:36:13 AM
They don't look close enough to me on a 400 but you are vastly more experienced so I will check before I decide to order a set.
Also can't remember if the original bolts have washers or the washer is built into the bolt - no idea what the right term is for that either. Found it on the inernet - its a flange bolt methinks!
Clearly I need to do some reading up on engineering terms.
Post by: taysidedragon on June 25, 2021, 12:09:02 PM
Ted, the original fasteners are flanged hexagon head. That means they have a smaller hexagon size and the flange means no washer required.
Post by: Bryanj on June 25, 2021, 12:29:35 PM
May be just the 500/550 long time since i did a 400
