SOHC.co.uk Forums => CB350/400 => Topic started by: 4wDaz on June 25, 2021, 05:25:45 PM
Would an engine come from the factory with all the same size conrods ? for example 4 no 2s ? or is it acceptable to mix them if the weights are the same ?
Mine were the same weight code but had different code numbers on the two that were still legible. Likewise two different codes on the crank webs.
Pretty certain they are original conrods.
Ive read your posts with interest as Im just measuring up to order new bearings, unfortunately no markings are legible on the crank only on the rods, 3 number 2 and a 3. I do have a spare number 2 from another engine so I was thinking I could make a matching set if required
I didn't find the crank web marks either the first time or the second time when I looked.
It needed me to clean the crank webs with some fresh petrol then concentrated looking in right place I found two of [attachimg=1]them.
Not easy to photograph with a phone - even now it takes me a while to find the marks again but they are there on my crank.
I have recored my crank mains, conrod details on a spreadsheet for future reference.
More the point you need matching weights not sizes
You cant always find the crank markings, on my 350F (or it could have been the 750K4 memories eh) they simply had disappeared. I tried the petrol trick and used a very bright LED magnifying lamp but never did find them. If that's the case you will need to measure them very accurately with a calibrated micrometre (this is to tenths of thou's), if you cant do it go to a machine shop and get them to measure them for you. It's very important that you get the correct size shells.
Ok Thanks, the current Con rods are all the same weight C, plus the spare Con rod I have is also a C. Would it have left the factory with different size rods but the same weights ?
I’ve tried but can’t read anything. I have treated myself to a new Mitutoyo digital micrometer and successfully measured the crankshaft journals but I have nothing to measure the crankcase with yet
Did you find any markings on the shell edges ?
I had to do a bit of educated guesswork from the ones that were colour coded then try them in an unmarked conrod using Plastigauge to check the clearance.
My understanding is that you do not have to measure the crankcase as they are stamped with the codes.
Yes the rods could be different sizes but same weight from new and the cases will be stamped and wont changesize uless the shells sieze to crank and spin which would destroy the cases anyway
No unfortunately, the crank had been removed from the engine by a previous owner years ago and the shells had been lost. Luckily the con rods were still attached but pistons had gone
So is it possible to get the bearing size without measuring the crankcase ? The cases are marked BBBAA
The main crank journals measurements are
No 1 – 31.986
No 2 - 31.986
No 3 – 31.987
No 4 – 31.988
N0 5 – 31.985
In the manual and the parts book is a cross reference table and in that you can convert the pin sizes to codes then use the table to get colour codes
If you look at the tables in the parts manual you will see that they used different markers in the tables. Letter codes on one axis for mains shells, the same axis in big ends uses number codes.
I too found it confusing - over time it makes sense - also the table layout themselves are obvious I guess to an engineer it was difficult for me to see the symmetry in the columns if you get my meaning.
Thanks i'll have a look when i get home from work and see if i can work it out. Im no engineer and moneys tight so I cant afford to order the wrong bearings, I'm sure i'll get the hang of it in the end
I've sent you a PM. Ted
I would suggest remeasuring as the smallest size listed by Honda for the crank journals is 32.000.
The tables show 32.0 down to 32.000 - 0.030 so that is down to 31.970 so what is wrong with his readings they look plausible to me or am I missing something here?
Ive checked them a dozen times
(https://i.imgur.com/XXKhE2y.png)
Trouble is you need a REALLY good micrometer to measure them accurately. By good I mean professional engineers workshop good. Probably costing hundreds if not into the thousands I'd imagine.
I have a new mitutoyo digital micrometer that i used but ill get it checked tomorow at the engineers whos doing my rebore
Where's that from Daz, my info came out of the official Honda parts book.
Well that's interesting, the workshop manual and the parts book show the same figures but in a completely different way. Seems Ted was right, I presumed it was a misprint as I've not seen Honda do that before, they tend to go up in sizes on the charts not down, so 1 would be 32.000 to 31.99 (who the hell writes figures like that) 2 would be 31.99 to 31.98 and 3 would be 31.98 to 31.97. Very odd and not something I've ever noticed before, the 500/550 shell bearing selection is far easier to understand.
I also have a Mitutoyo digital gauge and whilst it's good I don't think it's that good.
Its out of the 400 workshop manual in the Aladins cave download section http://info.sohc.co.uk/download/cb350f-cb400f-shop-manual/ (ftp://info.sohc.co.uk/download/cb350f-cb400f-shop-manual/)
If your figures are correct BTW, you'd need Brown, Brown, Brown, Green, Green. As all your figures are within the middle column and are thus No2.
Thanks for that, Ted came up with the same colours so I'm happy to go with that. Just need some overtime in now to pay for them ;D
