SOHC.co.uk Forums => CB350/400 => Topic started by: McCabe-Thiele (Ted) on August 02, 2021, 01:37:36 PM
Title: Wheel rim original size & what make tyres to fit ?
Post by: McCabe-Thiele (Ted) on August 02, 2021, 01:37:36 PM
I've just checked my old wheels they are fitted with the following that look original as regards rims etc the tyres have never been used on the road.
Front Rim is marked DID 1.60 x 18 Tyre fitted is a 3.00 x 18 Pirelli Tyre MT65  marked for US only (made in Brazil) they have rotational arrow marking.
Rear Rim is marked DID 1.85 x 18 Tyre fitted is a 3.50 x 18 Pirelli Tyre MT65  marked for US only (made in Brazil) they have rotational arrow marking.
As they are for the US market I can't see any obvious year of manufacture. I will probably just keep these as spare wheels as they are.
I am fitting new alloy rimmed spoked wheels of the same size just need to take advice on tyre brands of choice these days - last tyres I bought were Metzlers on my XJ900.
What tyre makes are folk using here on the 400/4 & aspect ratio to keep as standard ?
(https://live.staticflickr.com/65535/51353060649_d2c515b0a7_b.jpg) (https://flic.kr/p/2meTRPp)tyre markings (https://flic.kr/p/2meTRPp) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Title: Re: Wheel rim original size & what make tyres to fit ?
Post by: Green1 on August 02, 2021, 07:13:43 PM
Your tyre was manufactured the 39th week of 1995
Post by: TrickyMicky on August 02, 2021, 07:44:17 PM
 With the greatest respect Ted, the best thing for tyres which are 26 years old is a hacksaw cut right through them. I still have clear memories of a close friend of mine buying a used Suzuki Super Six which had been stood unused for just under two years. I watched as the rear tyre let go on him on a dry tarmac road. It will also enable you to see the condition of the rims on the inside. I always thought that my rims were in good condition, especially the rear one because it was kept rust free dut to chain lube fling. When I went to change the tyres, the insides of the rims were dangerously corroded. New standard size D.I.D. rims and spokes from Silvers, and to keep a fairly traditional look, I had Dunlop K82 tyres fitted. 3.00 x 18 front, and 3.50 x 18 rear. Classic tread pattern but modern rubber, and give enough grip for my antics, but at 74 years of age I think I'm probably more fragile than the bike now. Take care and have fun. Mike.
Post by: McCabe-Thiele (Ted) on August 02, 2021, 08:09:12 PM
Thanks Mike,
For the tyre age information they are too old to use I did not know the tyre age code - I agree completely at 73 yrs of age I too feel vulnerable on anything but the best rubber.
I have been a little ambiguos in my post I have no intention of using my old wheels & tyres I am getting a new set of wheels made up by central-wheels.
I'm after advice as to the best all round tyre brand and the correct size fitted as standard, the tyres do not appear to have an obvious aspect ratio unless I'm missing something.
Post by: K2-K6 on August 02, 2021, 08:56:50 PM
"I'm after advice as to the best all round tyre brand and the correct size fitted as standard, the tyres do not appear to have an obvious aspect ratio unless I'm missing something."
The aspect ratio I think, in broad terms, is because they are likely the same height as designated rim width and make them 100% with no protocol to mark them as default.
Post by: AshimotoK0 on August 02, 2021, 09:00:59 PM
For my CB250/350K'S  (Same size as CB400F)  I just bought Heidenau classic style 3.50 x 18 rear and 3.00 x 18 ribbed Anlas for front to try to replicate originals. Unfortunately very little available 3.00 x 18 in terms of ribbed classic tyres to give the original look ... unless anyone knows differently.
It's a pity we can't get these
https://www.yamiya750.com/index.php?main_page=product_info&cPath=179_274_193_223&products_id=3103
Post by: Green1 on August 02, 2021, 09:10:04 PM
Ash I think they look like the IRC Grand highspeed tyres that were on my 750 when I imported it.
Post by: McCabe-Thiele (Ted) on August 02, 2021, 09:35:13 PM
Online I see Avon & Dunlop make my sizes nothing from Metzler ?
Post by: SumpMagnet on August 02, 2021, 11:00:24 PM
Might also be worth looking at the new Michelin Road Classic tyres. I picked some up recently, and they feel pretty good. Been using Pilot Roads for years...from 2 to 5.....so I tought I would give their new classic tyres a go when I needed some old fashioned sized tyres.
Post by: billdn on August 06, 2021, 07:11:07 PM
Hi Ted
I run Dunlop K82 's - not too expensive and ride well enough  for my limited summer mileage.
Post by: McCabe-Thiele (Ted) on August 06, 2021, 10:03:22 PM
Hi Ted
I've been offered Dunlop K82 or Avon Road Runner 2 either @ £158 pair, or Metzlers @ £107 pair.
I liked the Metzlers on my XJ 900 they seemed good at resisting the overbonding wiggle!
Post by: billdn on August 07, 2021, 02:52:51 PM
Yes you're right they can have a tendency to pick up a seam in road repairs a little bit!
Post by: McCabe-Thiele (Ted) on August 11, 2021, 03:29:54 PM
Well dropped off my spare hubs today to get my wheels built at central wheel components.
I was advise that front  3.00 x 18 tyres of very difficult to get hold of - they tried to talk me into a slightly wider front rim but am reluctant to change it due to any clearance issues I might have ?
Anyone here know if its feasable to safely go slightly wider on the rim without issue on the mudguards etc , my rims are 1.6 x 18 Front & 1.85 x 18 Rear ?
Post by: TrickyMicky on August 11, 2021, 06:10:29 PM
Vintage Tyres of Beaulieu have 3.00 x 18 Dunlop and Avons in stock
Post by: McCabe-Thiele (Ted) on August 11, 2021, 08:20:01 PM
Thanks I'll see where it goes for now as I have been dealing with Warren at the wheel place who said he coud supply Avons that he recommended but he is abroad so I saw Chris instead.
Might just be an internal issue. I'll certainly look at the firm you mentioned i did not want them to build wheels that I could not find a tyre for - much appreciated. Ted
Post by: McCabe-Thiele (Ted) on August 12, 2021, 11:39:54 AM
Sorted they can now supply me with Dunlop or Avons. Thanks for the pointers to alternative suppliers.
Post by: Arfa on August 26, 2021, 11:31:20 AM
Bit late for Ted I know, but might be useful for somebody else. I'm not fussed by having a ribbed front tyre so read this in that light.
I've used Avon Roadriders on a classic and one pre-war bike with good success covering 10s of thousands of miles in all weathers. I'm used to these tyres so they were an obvious fit on the 400/4 for me. 90/90 x 18 front 100/90 x 18 rear with no clearance issues with standard tinwear.  They do give a 7% increase in rolling diameter for the front and 1% for the rear according to my sums. Change in diameter appears to have no effect upon the function of the main and side stands. When I checked the speedo with my GPS it was fine anyway, might be different for another bike. Absolutely fine when riding from walking pace to flat out on all the surfaces I've been on. Bend swinging is no problem and I've had no problems with stability under braking.
