SOHC.co.uk Forums => CB350/400 => Topic started by: McCabe-Thiele (Ted) on August 24, 2021, 10:59:55 AM
Title: Sump Oil Strainer unit
Post by: McCabe-Thiele (Ted) on August 24, 2021, 10:59:55 AM
I can see loads of muck on the insides of the oil strainer unit - if I attempt to remove the plastic type ring around the guaze will it all break or are they made to be dismantled ?
.(https://live.staticflickr.com/65535/51399448023_83c82f1bb2_h.jpg) (https://flic.kr/p/2miZBaH)sump strainer (https://flic.kr/p/2miZBaH) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Title: Re: Sump Oil Strainer unit
Post by: taysidedragon on August 24, 2021, 11:53:19 AM
I don't think they can be dismantled.  Just wash it through from the outside of the mesh , then let it dry before using.
Post by: Nurse Julie on August 24, 2021, 01:26:50 PM
They do come apart and the strainer and the body are separate part numbers. But, you most often wreck the strainer when trying to get them apart.
Post by: McCabe-Thiele (Ted) on August 24, 2021, 03:17:47 PM
I do not like the look of the muck on the inside funnel shaped part of the striiner might check availablity befor I wreck it?
DS show it as discontinued - might try a bottle brush from the inside with some petrol.
Post by: taysidedragon on August 24, 2021, 03:21:45 PM
I've got a spare one if you do wreck it. Spray some degreaser or paraffin down it to loosen things up, then
wash it through.
Post by: Nurse Julie on August 24, 2021, 03:24:50 PM
No longer available Ted, either from DS or CMS.
I always soak ours in the parts wash for a few days, rince out thoroughly with parts wasb fluid or diesel and repeat. They always come up nice and clean.
Post by: McCabe-Thiele (Ted) on August 24, 2021, 03:44:06 PM
I'll do that Julie just tried a quick petrol wash and it went black immediately so clearly needs a good soak in parts wash - petrol is a bit harsh on the rubber part.
Post by: Athame57 on August 24, 2021, 08:46:10 PM
Faced with their imminent extinction  :o and if no pattern part emerges to fill the void, can more frequent oil changes be enough to cope with not having one at all?
Post by: Bryanj on August 24, 2021, 10:56:19 PM
Aeroslo brake cleaner
Post by: Athame57 on August 24, 2021, 11:49:34 PM
Sorry....I don't understand!  ;D
Post by: SteveD CB500K0 on August 25, 2021, 06:45:00 AM
Get a can of spare-on brake cleaner. That blasts most muck off.
[Bryan Jones translation service].
Post by: Charlie J on August 25, 2021, 07:16:42 AM
I think he means "spray on" brake cleaner
[SteveD translation service].   8)
Post by: Charlie J on August 25, 2021, 07:34:37 AM
Sorry Steve, I just couldn't resist doing that  :) :)
Post by: SteveD CB500K0 on August 25, 2021, 08:00:28 AM
Hoist by my own …
Post by: Bryanj on August 25, 2021, 08:39:00 AM
I keep telling you my keyboard is dyslexic
Post by: McCabe-Thiele (Ted) on August 25, 2021, 11:47:42 AM
I  suspect it's needed as all cars have them as well as an oil filter- if you have debris in the gearbox for instance (where engine/gearbox share the same oil) it's going to drop into the sump and get sucked into the pick up so a strainer is essential in my view to keep out large bits of metal or rubber etc.
In the complete absence of a replacement I guess it will be a case of adapting one from another engine and joining it to the same end fitting.
Post by: Bryanj on August 25, 2021, 03:21:56 PM
It has to be there as the hole it fits into snugly is too high upnfor oil to be reliably sucked in
