SOHC.co.uk Forums => CB350/400 => Topic started by: billdn on August 25, 2021, 04:10:26 PM
Title: Rear brake pedal alignment marks.
Post by: billdn on August 25, 2021, 04:10:26 PM
Should these 2 marks on pedal and shift align or is it just coincidence 🤔.  If so how because the spring doesn't want to go that far under tension.
Title: Re: Rear brake pedal alignment marks.
Post by: Nurse Julie on August 25, 2021, 04:36:40 PM
Yes, that minute little black divot on the end of the shaft lines up with the divot on the lever. You may have to move a spline or two either way for comfort of your foot but the dots are the starting place.
[attachimg=1]
Post by: McCabe-Thiele (Ted) on August 25, 2021, 04:37:23 PM
I've just checked my rear brake pedal shaft  - there is no marking aside from the small scratch I enscribed before removal to realign when I refit the pedal.
Likewise there is no spot on the pedal itself either - both I'm pretty sure are original parts.
Confusing as you seem to have two spots one is a small dot the other a circle?
I've just had another look after rubbing the end of the shaft with some fine emery paper and can make out a letter T -it's nowhere near the top either!
My new brake pedal does have a spot like yours though - I havent as yet fitted mine so will be interested to read how you sort it.
Post by: billdn on August 25, 2021, 06:30:37 PM
Cheers NJ - my pic looks almost identical to yours, so may be a spline or 2 adjustment needed for comfort.
