SOHC.co.uk Forums => CB350/400 => Topic started by: AshimotoK0 on September 15, 2021, 07:40:13 PM
Title: 400 Carbs from a Bloke in Hull
Post by: AshimotoK0 on September 15, 2021, 07:40:13 PM
My mate in Beverley can't get his 400/4 carbs to perform properly (despite U/S cleaning etc. ) and he was away on Holiday so asked me to make an offer on these eBay ones, from a bloke near me in Hull (he had borrowed my Gerben restored ones and the bike ran perfect with my carbs fitted).
https://www.ebay.co.uk/itm/224607055306
I went to pick them up the same day as buying them and it seems the seller is a retired engineer and refurbs them to sell on. Must admit, I am well impressed .. refitted with all Keihin brassware .. all steel parts nickel plated, cleaned up alloy but not too 'blingy' and set-up and tested on his own superbly restored 400/4.
I can pass on his details if anyone is interested .
Title: Re: 400 Carbs from a Bloke in Hull
Post by: Bryanj on September 15, 2021, 08:35:27 PM
Thats cheap
Post by: Cookie2050 on September 16, 2021, 11:35:15 AM
Speaking about carbs, what do people think about these carb rebuild kits on E Bay. im sorting mine out at the moment and if they leak when i test them will they be the best soloution
Post by: Sesman on September 16, 2021, 12:38:01 PM
Which ones, there are many?
Contact Nursejulie of this forum who can supply O-rings, JIS screws etc. Try to retain your original brass if you can.
Post by: Athame57 on September 16, 2021, 03:44:06 PM
(https://images.cmsnl.com/img/products/holder-set-aadj_medium16029323004-01_7e8e.jpg)
What I've always wanted to find, to no avail so far, is a source for getting those rubber parts in the carburetor holder set separately. Anyone know?
Post by: Bryanj on September 16, 2021, 04:27:40 PM
As far as iknow they dont exist unless you can make your own
Post by: Charlie J on September 16, 2021, 05:02:47 PM
The rubber parts fell to pieces when refurbishing my carbs. Am I ok to assume it’s ok to run without them?
Charlie
Post by: McCabe-Thiele (Ted) on September 16, 2021, 06:35:31 PM
Charlie
I can't work out what they do aside from making it easier to assemble all four carbs onto the mounting plate.
Post by: Athame57 on September 16, 2021, 07:11:31 PM
Almost anything rubber that isn't a seal, electrical or your tyres I'd put down to being for suppressing vibration.
Post by: Nurse Julie on September 16, 2021, 07:34:57 PM
Dust covers.
Post by: Bryanj on September 16, 2021, 08:29:12 PM
Correct, keeps the secret additive out of the ball joints      alegedley
Post by: Athame57 on September 16, 2021, 08:54:53 PM
Dust covers.
So we don't need to panic if they crumble when we dismantle a bank of carbs for renovation?
Post by: Laverda Dave on September 16, 2021, 08:55:29 PM
I think they are a bargain especially if he keeps the original brassware. Pattern parts can be a nightmare especially the float valves that always seem to leak. I like the level tube, I must try and make one of those, got to be easier than setting the floats with a gauge that can also be a bit hit and miss.
Post by: Nurse Julie on September 16, 2021, 08:59:34 PM
Dust covers.
No George, no need to panic. The carbs function just fine without them.
Post by: Cookie2050 on September 17, 2021, 08:58:46 AM
I will do, got some of Nurse julie's seals in my oil pump :D
Post by: AshimotoK0 on September 17, 2021, 09:46:27 AM
The Hull guy gets his Viton seals locally .. he also has a batch of the  little machined press in pins that retain the the carb operating shaft in the main alloy mounting plate..... such is the attention to detail. I would say the carbs that he sold my mate were at least as good but not as  'blingy' as the Gerben ones I have .. My Gerben ones have pattern brassware and a spray painted alloy plate and replated but slightly nadgered JIS screws ..plus this guy tests/syncs the carbs on his own 400/4. OK you can't hope to then put them on your own 400 and not have to re-do them but they must be  pretty damn close. He has offered my mate £60/70 for his old set.
Attached is the pic of the carbs we bought synced on the sellers bike.
Post by: teenybop1 on September 20, 2021, 11:56:31 AM
Is the guy on ebay Hydro Paul?, thanks
Post by: AshimotoK0 on September 20, 2021, 02:22:38 PM
Yes .. that's him.
Post by: PaulC on September 29, 2021, 05:11:59 PM
I'd definitely like his details please as I'm just started stripdown on my 76 CB400 that's been sat in a garage for 11 years.
TIA
Post by: AshimotoK0 on September 29, 2021, 09:59:03 PM
TIA
I just need to phone him for you and another member to make sure he's happy taking on the work.
Hi ...  I called him and he doesn't really take on carbs for other people. He just builds set when he can get the and then sells them on eBay. I think somebody on here contacted him via eBay and he is telling them when the set he is currently doing. he offered £60-£70 for my mates old set.
