SOHC.co.uk Forums => CB750 => Topic started by: Johnny4428 on November 13, 2021, 01:59:07 PM
Title: 750 Carbs (657a)
Post by: Johnny4428 on November 13, 2021, 01:59:07 PM
Thought I might tackle the carbs the day but not wanting to go further than I need to. I have separated the carbs no problem there and there is much crud! Just want advice on this tricky looking fitting on the throttle shaft. I would like to dismantle completely to clean properly.
Title: Re: 750 Carbs (657a)
Post by: Nurse Julie on November 13, 2021, 02:14:31 PM
You need to drill out the pin at the other end of the bar Johnny. Be careful because there are crush washers under that bolt and screw on the left of your pic, don't loose them.
Post by: Johnny4428 on November 13, 2021, 03:53:37 PM
Thought as much Julie! Thanks, didn’t know about crush washers. Cheers!
