Other Stuff => Misc / Open => Topic started by: Johnny4428 on December 21, 2021, 11:45:13 AM
Title: Plastic throttle tube.
Post by: Johnny4428 on December 21, 2021, 11:45:13 AM
Quick question! Lube or no lube? Maybe a little on the cable end but not on the bars? I’ve not had any bother in the past but just wondered about the correct or recommended application.
Title: Re: Plastic throttle tube.
Post by: taysidedragon on December 21, 2021, 12:13:11 PM
I've always put a smear of light oil on the bar, not sure if it's necessary, but never caused a problem.
Post by: Oddjob on December 21, 2021, 01:06:04 PM
Always lube the bars myself. Usually silicon grease or oil.
Post by: McCabe-Thiele (Ted) on December 21, 2021, 06:18:58 PM
I used Silicone Spray lubricant after thorough cleaning.
I use silicone spray instead of grease on my garage door mechanism as it does seem to attract the dirt & clog like normal oils & grease.
Post by: Johnny4428 on December 21, 2021, 10:50:44 PM
Thanks guys, I have fitted using silicon spray on bar and lithium grease on cable end of tube.
