SOHC.co.uk Forums => CB350/400 => Topic started by: Dave on December 21, 2021, 07:30:14 PM
Title: Float Height Anomaly
Post by: Dave on December 21, 2021, 07:30:14 PM
I'm trying to adjust the float height. As you can see with the attached images, one side is set perfectly at 21mm (400F). However, when I check the other side there is a gap of about 1 and a bit mm. Laying the float on a flat surface shows no obvious twists or distortions.
[attach=1] [attach=2]
I'm not sure what I should do next...
Dave
Title: Re: Float Height Anomaly
Post by: Nurse Julie on December 21, 2021, 07:32:58 PM
Just push that side of the arm up a tad, or push the other side of the arm down a tad (do this with the float removed) . There is a twist or bend there somewhere.
Post by: allankelly1 on December 21, 2021, 07:35:51 PM
Yes I had this on two of my carbs
Like Julie said  they  are easy to bend /twist on the brass arm if needed but just be gentle with it
Best wishes Al
Post by: Dave on December 21, 2021, 08:27:14 PM
Thanks for the feedback. Appreciated!
Yes Julie, definitely!! I'll let you know how I get on...
Thanks Al, I have exactly the same situation.  I don't feel so bad now ;-)
Post by: allankelly1 on December 21, 2021, 08:30:05 PM
No problem
To help I made up a float height gauge on my 3d printer to check that both floats are level be easy to copy with a piece of card or plastic
(https://uploads.tapatalk-cdn.com/20211221/ed8fc4fdfc8b1199f85016b48b2972ee.jpg)
Made life so much easier
Best wishes Al
