SOHC.co.uk Forums => CB350/400 => Topic started by: Athame57 on January 19, 2022, 01:52:16 PM
Title: The horn of death...
Post by: Athame57 on January 19, 2022, 01:52:16 PM
Every time (well, twice in a row) I try to bib my hooter the main fuse blows.  :o  I can't say I've looked too hard yet, but has anyone else had this, or any ideas?
Title: Re: The horn of death...
Post by: Johnwebley on January 19, 2022, 01:59:51 PM
Any noise from the horn?
I would suggest you disconnect the wires from the horn,
Try a test bulb/lead,check the power lead to earth,
Connect the bulb between the 2 connectors, does the bulb light when you press the horn button?
Post by: Alexrayz on January 19, 2022, 02:06:44 PM
Maybe you could keep it as such and have an extra emergency off switch. Just need to holler whenever you need to.
No?
Ah well. Maybe your horn is just shorted out and needs replacement.
Post by: McCabe-Thiele (Ted) on January 19, 2022, 10:12:31 PM
Certainly car horns can short out & blow a fuse.
Post by: TrickyMicky on January 19, 2022, 11:34:46 PM
Is it the standard horn fitted?  Some time back I fitted a pair of Fiamm type horns which really are effective, but the load was too much using the standard wiring, so I had to fit a relay. By all means check your current wiring and connections/earths, but if you get a chance, also look at the multi connector fitted behind the fuse holder. On mine, the internal blade connectors had all turned green and the main fuse was unable to cope with the extra load of pulling enough current through for high amp items.
Post by: Sesman on January 20, 2022, 06:44:16 PM
“Horn of death” was that John Bindon or John Holmes’s?
Post by: Sesman on January 20, 2022, 06:46:06 PM
Damn…wrong  forum again.
Post by: Athame57 on January 21, 2022, 12:33:59 PM
It turned out to be a barred wire probably touching the frame, insulating tape for now, horn works without gazunking the electrics now!  ;D
Post by: Bryanj on January 21, 2022, 03:05:27 PM
Was it barred from pubs as well as clubs so got anoyed?
Post by: Athame57 on January 21, 2022, 06:04:44 PM
ooops...a typoo, I meant barbed!
Post by: Bryanj on January 21, 2022, 07:32:26 PM
Cant complain, my dumfone does loads of them!
