SOHC.co.uk Forums => CB500/550 => Topic started by: alexdecker on April 07, 2022, 07:46:25 PM
Title: What engine parts are chrome?
Post by: alexdecker on April 07, 2022, 07:46:25 PM
Hey all
On a CB550F, what part of the engine is chrome? Repainting, and don’t wanna paint parts that should be chrome? Also, is there any recommendations besides how it came out of the factory, as to what should be chrome?
Title: Re: What engine parts are chrome?
Post by: Johnwebley on April 07, 2022, 07:55:45 PM
I think only 4 items are chromed,
Points cover
Starter cover
And both cam end caps.
Post by: Trigger on April 07, 2022, 08:05:55 PM
End caps not chrome just, points cover and starter motor cover  ;)
Post by: alexdecker on April 07, 2022, 08:13:53 PM
Thanks. Is anything else polished, or just painted? When I look at restorations, they often look shiny many more places. But what I’m hearing is that I can paint the entire engine bar points and starter cover, and it will be a resto true to factory spec?
Post by: Oddjob on April 07, 2022, 08:37:33 PM
What about kick start lever???
Bolts that hold the starter cover on.
Screws that hold the points cover on. Screws that hold the cam end caps.
Post by: alexdecker on April 07, 2022, 08:49:43 PM
Ah, I’m just talking engine cases here.
But - was the screws painted originally? I ordered new shiny ones for most of the engine though…
Post by: Oddjob on April 07, 2022, 08:56:43 PM
The points cover screws were chromed, raised countersunk ones. Same for the cam end caps screws.
All the casing screws were zinc plated.
Post by: alexdecker on April 13, 2022, 03:21:25 PM
Got the engine painted. Was a little in doubt - do you guys usually paint the tappet covers as well as the oil covers etc? Basically all that screws in? Or do you polish them?
[attachimg=1]
Post by: McCabe-Thiele (Ted) on April 13, 2022, 03:23:26 PM
Looking good.
Post by: Laverdaroo on April 13, 2022, 04:04:11 PM
Nice,
asab rule Id say polished screws but I had all mine vapour blasted and clear ceracoted. Your call basically.....
Post by: Oddjob on April 13, 2022, 04:18:02 PM
Sometimes it's nice to paint them a different colour to the engine for a contrast. I've had them chromed in the past, there are some chrome ones available (tappet covers) on Ebay.
Engine casings, your choice, polished, chromed or satin silver or even satin black for contrast. My last engine I did I had every part that bolted to another part a different colour, either silver or black, so if the crankcases were silver the barrels were black, the head was silver and the camcover black with the breather cover silver etc. It sounds a bit OTT but in fact it looks very nice.
Post by: alexdecker on April 14, 2022, 09:03:56 AM
Thanks for those responses!
Wondering - the exhaust flanges and collars - were they chrome originally? Mine are pretty rusted, and instead of buying new ones, I could paint them. But if they are originally chromed, I might go with that look instead…
Post by: Sesman on April 14, 2022, 11:09:19 AM
That’s a nice looking, clean paint job Alex. Which paint did you settle on?
Post by: Bryanj on April 14, 2022, 12:33:35 PM
Exhaust flanges chrome, collets not
Post by: Oddjob on April 14, 2022, 12:41:13 PM
Yes the exhaust flanges were chrome, however they are very roughly cast using a sand mould by the look of them. If you attempt to get them rechromed it won’t last long as the surface is too rough to accept it and only really the edges of the fins and the parts around the stud holes come out any good. They tend to rust like hell at the bottom of the fins after even a very short time.
Been there, done that, learnt the lesson.
I have a thread in the project corner section called 30 years of storage later, check out page 2 and you’ll see what I did to get round this problem.
The collared were zinc plated, due to the very high temps they are subjected too painting, even using VHT paint, doesn’t tend to last. I also did the collars in the same way as the flanges, almost ready to take them to get done, one set of flanges will be chromed, one set will be done by another process and all the collars will also get this process. If you can wait a few weeks you’ll see the results.
Post by: smoothoperator on April 14, 2022, 12:59:28 PM
As I invested in a zinc plating kit, and my flanges were rough, I have zinc plated them. Nothing too much to lose but initially they have come out OK. Took a few efforts though. I plated a couple of collars but this took a lot of prep, so I ducked the other 6. I've painted all 8 with VHT paint.
Post by: Oddjob on April 14, 2022, 01:45:52 PM
Sorry to say but I doubt they'll last. Unless you smooth out those casting marks everything just falls off eventually as the marks allow water underneath the coating (whatever it is) and that blows it off from below, as the water gets hot it expands and just bursts through.
I tried VHT satin black paint on the collars, it sort of lasted but they were showing rust through it within months. Zinc plating may work but the surface would have to be smooth or the same as the flanges will happen IMO. I hope I'm wrong and it works for you but I'm pessimistic that it will.
Post by: alexdecker on April 14, 2022, 02:47:33 PM
I ended up going with VHT Engine Primer and VHT Engine Enamel in Nu-cast aluminium :) The prep work was horrible, but really paid off, as it made the actual paint work a snooze and I am really pleased with the result. Baked it, and considering doing another wash or two, just to make sure I got all the last dirt out before reassembling :)
Post by: alexdecker on April 14, 2022, 02:52:50 PM
Just looked at your thread. Phew, quite a lot of hours put into that! I kind of want the same result, but I don't have the time for the complete job right now. I think they are going to get a spin on the wire wheel, and then I'll keep it at that for now. Won't paint them though!
