SOHC.co.uk Forums => CB500/550 => Topic started by: alexdecker on April 14, 2022, 09:54:29 PM
Title: Cleaning and de-rusting old engine bolts
Post by: alexdecker on April 14, 2022, 09:54:29 PM
Hey all
Putting all my engine bolts (outer ones) through the wire wheel to remove rust and make them look like new. BUT - they will probably rust again in a few months I would imagine.
How do you guys treat your bolts? Zinc plate them, or?
Title: Re: Cleaning and de-rusting old engine bolts
Post by: Oddjob on April 14, 2022, 10:08:32 PM
Yeah, Zinc or Zinc/Nickel plate.
Or replace them with stainless steel ones.
Depends a lot Alex on what state they are in to start with.
Post by: alexdecker on April 16, 2022, 02:56:36 PM
They are sorta okay. It is the bolts that attaches the engine to the frame though, and I haven't been able to find stainless steel replacements for those yet (the long ones at least. Haven't looked for the short ones yet).
Is there replacement sets for the bolts attaching the engine to the frame?
Post by: haynes66 on April 16, 2022, 05:18:08 PM
the answer is obviously zinc plating, but when i was very short of cash, i cleaned them as you have, spray them with galv spray and let them dry. when fitting, use a good fitting socket and once it's tight, spray some galv paint into a small container and brush it on with a small brush to cover the marks left by the spanner/socket. not great, but better than bare steel which will rust within hours
Post by: SumpMagnet on April 17, 2022, 01:32:46 PM
Zed Parts do a complete engine mounting bolt set, including the long bolts.
Post by: alexdecker on April 17, 2022, 03:30:08 PM
Wow, hadn't seen that one. Might actually go for a set like that :)
