SOHC.co.uk Forums => CB500/550 => Topic started by: Rolfbulmer on April 21, 2022, 09:11:53 PM
Title: What year is my cb 550 please
Post by: Rolfbulmer on April 21, 2022, 09:11:53 PM
Hi guys,
I have recently acquired a honda cb550F.
The V5 says it was registered in 1979.
The frame No. is CB550F-2113328
Engine No. is CB550E-1153025
My research makes me think it is an F3 from 1977
Could anybody please let me know if this is correct. Also does it look like the frame and engine are 'matching'.
Title: Re: What year is my cb 550 please
Post by: Nurse Julie on April 21, 2022, 10:41:18 PM
Welcome to the Forum. If its an original 1st registered UK bike (ie, not a USA import) it can't be a F3 as we only ever had F1 and F2 in the UK model range. Also, if it is a UK model, its no good looking at USA engine / VIN numbers, which is what is generally found on the Internet. Is it an import or a 1st registered UK bike?
Post by: deltarider on April 22, 2022, 07:30:26 AM
There was no F3. It's an American 'invention': the US market is used to a new model every year, for marketing reasons, but Honda never produced a F3. If you want to identify your model exactly, there's p.4 in the Parts Lists: https://www.honda4fun.com/dwnload/Part-List/CB550/CB550-F2-Parts-List.pdf
Post by: Bryanj on April 22, 2022, 08:22:49 AM
Similarly it has to be late registered if 79 but there were a lot left in crates
Post by: Rolfbulmer on April 22, 2022, 04:18:03 PM
Thanks for the replies.
Nurse Julie: I believe it is a first registered UK bike.
Deltarider: thanks for the link - It would appear that the frame and engine number could be any of the options on the list on page 4, so confusing for me.
Bryanj: Yes, I thought that also, all adds to my confusion.
Post by: Oddjob on April 22, 2022, 04:21:18 PM
Any pictures of it?
It could be a K3 but wearing a lot of F parts. Pictures would show us if it is as there are a few differences.
Post by: Rolfbulmer on April 22, 2022, 04:46:05 PM
Hi Oddjob,
No pictures that would help as bike mostly in bits at the moment. The picture in my avatar is the most complete.
The USA forum have sent the below;
Hi and welcome.
The model guide shows it to be a '77 F2....
http://www.sohc4.com/cb550/cb550/#cb550f
Post by: Bryanj on April 22, 2022, 05:31:50 PM
Top of the carbs is one givaway, "P" shaped with a screw top and bottom is K3, Coffin shaped with a screw each side is an F
Post by: Oddjob on April 22, 2022, 05:54:18 PM
Check rear of swinging arm, if fully enclosed it's an F type, if it has removable end caps it's a K.
Tubular type rear brake lever K, flat type F.
Post by: deltarider on April 22, 2022, 08:49:57 PM
Important in that Part List is p.17 (clutch modification): https://www.honda4fun.com/dwnload/Part-List/CB550/CB550-F2-Parts-List.pdf
Post by: Sesman on April 23, 2022, 06:37:07 AM
What was the modification please? I can’t seem to see one specifically identified. Or,do,you mean the F2 differs from  the F1 and K models?
Post by: Oddjob on April 23, 2022, 06:58:35 AM
It's the central pressure plate Phil I believe, was modified after a certain engine number. No 6 and 7 on the list on page 17.
Post by: Bryanj on April 23, 2022, 07:00:58 AM
Is that the double steel plate in the stack Ken?
Post by: Sesman on April 23, 2022, 07:09:39 AM
Thanks, Ken. I’m guessing that’s item 6 changed to a 7? I ask as my clutch has an item resembling the ‘7’. Double sided as suggested by Bryanj.
Post by: Sesman on April 23, 2022, 07:18:46 AM
Thought so…it’s featured in the workshop manual.
Post by: deltarider on April 23, 2022, 10:49:27 AM
That's not necessarily what p.17 in the Parts List is about...
Post by: Sesman on April 23, 2022, 11:12:31 AM
You’ve lost me there. It was the change to clutch disc that interested me and it’s featured in both documents…unless I’ve missed something, which is entirely possible.
Post by: deltarider on April 23, 2022, 12:01:08 PM
From where that particular modification came into effect, is clearly indicated in the Parts List by specifying the precise engine number. Not in the Shop Manual.
Post by: Oddjob on April 23, 2022, 12:55:20 PM
Yes the double plate Bryan.
Odd, the supplement has a slightly earlier engine number than the parts list for when it changed.
Post by: Rolfbulmer on April 24, 2022, 10:15:08 AM
Thanks Bryanj, carb tops are coffin shaped with screws either side.
Thanks Oddjob, swing arm is fully enclosed.
So with all the great replies I've had my conclusion is that I have a 1977 F2.
