SOHC.co.uk Forums => CB350/400 => Topic started by: McCabe-Thiele (Ted) on June 23, 2022, 06:21:23 PM
I presently have a small digital voltmeter mounted on the handlebars between the mounting brackets.
It works just fine but in bright daylight you can't read the display.
Has anyone here fitted a small diameter Analogue guage -the old headlamp mounted units would be ideal you could fit a raised type unit in a suitable housing?
Not fitted one to a honda but be careful of type and wiring, there are two types
1 moving iron==cheap
2 moving coil ==dearer
The no1 uses more current to give a reading and if connected directly accross the battery to read all the time would totaly flatten the battery fairly quickly, on a neighbours spridget several years ago about 3 days
My present digital unit is wired via a relay that is activated when sidelight/dtrls are on.
When the 750 was contemporary a friend made a small pod (engineering apprentice) that fitted between the two dial, also a rear cap in aluminium to match the Honda chrome disc on existing clocks. That did look good but you'd need a decent turner to make it up for you.
The inspiration was this
[attachimg=1]
and just seen at top of picture, it made the addition look like a factory fitment and very neat with a analogue clock he wanted to include.
Perhaps some inspiration for you.
Neat looking fitting Nigel.
Hi Ted,
In terms of positioning I think it’s down to personal choice. If you look at my “Cockpit Upgrade†post you will see I accommodated 6 gauges. The AFR gauge was a little lager in diameter so would not sit as low as the others.
In terms of housings it depends what you can create with the garage resources you have available.
I am pleased with the good info that mine provide, and the wiring you have should work fine, but I would go for a gauge that has a damped movement, to avoid needle vibration.
Hope this helps.
Great that you are now on the road.
All the best
Hi Ted,
Hope this helps.
All the best
Hi Dennis - I had forgotten that post - I was hoping I could find a handlebar mounted analogue gauge as I've seen on the net but can't find anyone who sells the. Thanks Ted
