SOHC.co.uk Forums => CB350/400 => Topic started by: Matt_Harrington on July 11, 2022, 06:17:37 PM
Title: Fuel lines from carbs
Post by: Matt_Harrington on July 11, 2022, 06:17:37 PM
Could someone tell me how long these lines are that are labelled (2)
[attachimg=1]
Do they just 'dangle down' in case of an overflow?
Item (1) was very hard and difficult to remove but I can replicate that one easily.
Title: Re: Fuel lines from carbs
Post by: Nurse Julie on July 11, 2022, 06:31:22 PM
If you make them about the same length, once fitted, as the float bowl drain tubes, that'll be about right. They are air vent tubes, they just dangle down to atmosphere.
Post by: Matt_Harrington on July 11, 2022, 06:35:48 PM
Ta very much! I'll let them dangle!  ;)
Post by: ka-ja on July 11, 2022, 07:50:27 PM
They fall between the rear of the engine casing and the frame, and are held together in a square shaped plastic former.
Post by: Deano400 on July 11, 2022, 09:41:48 PM
The two carb vents go over the air manifold and down between the crank case and swing arm.
[attach=1]
[attach=2]
Post by: Matt_Harrington on July 12, 2022, 02:45:01 PM
Thanks - those are useful for the routing. Matt
