SOHC.co.uk Forums => CB500/550 => Topic started by: alexdecker on July 21, 2022, 06:42:40 AM
Title: Rear brake on CB550F question about design
Post by: alexdecker on July 21, 2022, 06:42:40 AM
Hey all
Assembling the rear brake. The brake pedal stem is a slightly different design than earlier models it seems, and it has an extra arm with some sort of hook on it. I can't figure out what the hook is supposed to hook on to or what its purpose is. Can anybody help?
Title: Re: Rear brake on CB550F question about design
Post by: alexdecker on July 21, 2022, 06:48:02 AM
Mmh… realising right now it must be the spring it hooks on to! Already installed the back wheel though, and it seems I have to disassemble that again to even install the brake pedal stem. Damn.
Post by: Bryanj on July 21, 2022, 07:36:04 AM
Swing arm out as well
Post by: alexdecker on July 21, 2022, 09:39:52 AM
Ok, the spring is on the outside of the bike, not inside where that hook is. Can someone tell me or if anyone has a picture of how to mount this correctly? What goes in that hook on the second arm of the brake stem?
Post by: Bro550F on July 21, 2022, 11:22:57 AM
Any photos, would help??
Post by: Sesman on July 21, 2022, 12:17:46 PM
Does this help?
Post by: FlyinPhil on July 21, 2022, 01:15:33 PM
I made this mistake as I followed a build thread from an earlier K model and then found out when I had installed the lovely new swingarm and rear wheel that I couldn't get that brake arm pedal in.  So out came the rear wheel and swing arm again to install it.  I just put it down to experience and its all part of the fun, and yes the little hook is for the little spring which connects the arm to the brake pedal switch.
Post by: McCabe-Thiele (Ted) on July 21, 2022, 04:08:19 PM
I was fortunate not to make a similar error on my 400 - when asking about fitting the bronze bushes into the swing arm I was forwarned about fitting the brake pedal lever before fitting the swing arm into the frame.
Post by: alexdecker on July 21, 2022, 05:15:46 PM
I did exactly this :) Ah well, corrected the error today.
One question though - does anyone know where the brake pedal adjuster bolt is on my model? I can't find it on the parts list.
Post by: Bryanj on July 21, 2022, 05:31:23 PM
EITHER outside the frame pushing down on the pedal OR behind the frame tube pushing on one of legs of the bit you cant fit
Post by: Seabeowner on July 21, 2022, 06:54:42 PM
Brake pedal adjuster bolt hole is inboard of the main frame tubes. Short bent bit of meatal for 6mm bolt that bears on the back of the arm that the pulls the brake rod. The other arm on the this shaft with the hook is for the spring of the rear brake switch.
Post by: alexdecker on July 21, 2022, 08:43:50 PM
Ok, so something weird here.
When I took the bike apart, this screw was placed in that screw hole:
[attach=1]
But when I try to refit it now, it seems the screw is too big, and is ruining the thread. See this picture. Don't know if it is just because of the powder coating, but it definitely seems as if the screw is way to big for the hole.
[attach=2]
But I have a before picture of that screw in that exact hole! What do you guys think?
Post by: McCabe-Thiele (Ted) on July 21, 2022, 08:54:20 PM
If you are certain you  took that bolt out of the thread and it seemed normal then a tap down the thread should  remove any powder coating layer.
Post by: Oddjob on July 21, 2022, 09:39:03 PM
TBH it looks like the bracket is bent out of shape, it should be flat and it should be threaded M6 x 1.00, that bolt could be UNF as it appears a bit coarser than standard.
Post by: Sesman on July 22, 2022, 07:38:15 AM
Second oddjob comments. The plate should be flat eg perpendicular to the brake arm.
Post by: Bro550F on July 22, 2022, 08:21:25 AM
As mentioned above, straighten bracket so it's perpendicular to the plate, then run the tap through the hole and offer the bolt to the tap to check the threads are the same before trying to force the bolt in. After tapping it should go in by hand.
