SOHC.co.uk Forums => CB500/550 => Topic started by: Davelu88 on August 15, 2022, 10:12:51 PM
Title: Jet Set O Ring
Post by: Davelu88 on August 15, 2022, 10:12:51 PM
Hi All , I ordered the Keyster carb gasket set from DS and the O ring for the Jet Set does not seem as thick when put on as the old one was . Is this normal ?. Many thanks Dave
Title: Re: Jet Set O Ring
Post by: Nurse Julie on August 15, 2022, 10:19:02 PM
They are not genuine O rings Dave and they are also not Viton, so not Ethanol / modern fuel resistant.
If you are concerned,  I sell full Viton Carb O ring kits for your bike.
Post by: Davelu88 on August 15, 2022, 11:04:00 PM
Sent you a pm Julie
Post by: Bryanj on August 15, 2022, 11:55:48 PM
Was it the full repair kit or just the gaskets you bought? Comes up regularly on the US forum that the keyster brass is not very accurate
Post by: Davelu88 on August 16, 2022, 11:14:18 AM
Just the gaskets Bryan , it is not even close to filing the groove in the jet , just seems too loose
