SOHC.co.uk Forums => CB500/550 => Topic started by: McCabe-Thiele (Ted) on September 18, 2022, 03:55:31 PM
Title: Brake union thread type & bleed nipple.
Post by: McCabe-Thiele (Ted) on September 18, 2022, 03:55:31 PM
Sadly my stock of brake unions & bleed nipples mostly went in the bin as they not metric. The few metric unions  I have are too short.
Our local motor spares place shut after Covid - can someone sende a link or telle the size as my flaring tool is still good. Thanks.
Title: Re: Brake union thread type & bleed nipple.
Post by: Bryanj on September 18, 2022, 04:14:04 PM
Honda use the odd size m10 Ted and i think the bleed nipples are m7, will check and confirm later,
Post by: Bryanj on September 18, 2022, 04:30:12 PM
M10x1.25 is the pipe thread, cant remember where my spare bleed nipples are but it was a new one in the 500 mate, 8mm spanner size from memory and even if its only been in there a short time warm the caliper body and use a ter wrench to undo
Post by: McCabe-Thiele (Ted) on September 18, 2022, 05:03:37 PM
My m7 was too big, nipple a tad rounded had to put it in the vice & rotate the the caliper half.
Brake pipe was pinched & twisted - snapped the pipe within a fraction of a turn. No Biggie I have plenty of new pipe.
Post by: Bryanj on September 18, 2022, 05:37:50 PM
Careful with new pipe nuts Ted, old imperial when flared had a cone on the end of the pipe that was both sides, dies marked 3/16, metric was only flared on the front and flat backed, dies marked  4·75. I have seen metric pipe nuts advertised that need the imperial flare type
Post by: Nurse Julie on September 18, 2022, 05:55:04 PM
I've got the bleed nipples in stock Ted.
Post by: McCabe-Thiele (Ted) on September 18, 2022, 06:13:17 PM
I've sent a PM.
Post by: Nurse Julie on September 18, 2022, 06:19:06 PM
I've sent a PM.
Yep, received that thanks Ted.
