SOHC.co.uk Forums => CB500/550 => Topic started by: SPR on September 21, 2022, 05:24:02 AM
Title: Carb balancing - stupid question ......
Post by: SPR on September 21, 2022, 05:24:02 AM
Morning
Before I balance the carbs ... a question about connecting an auxillary fuel tank.
The 500 has two fuel pipes whereas the 550 had one .. do i need to feed fuel to both pipes using some sort of Y connector ?
Yes I know - basic question :)
Simon
Title: Re: Carb balancing - stupid question ......
Post by: Sesman on September 21, 2022, 05:39:28 AM
Yes, I use a Y piece. The 550 has a Y piece down stream of the tap
Post by: SPR on September 21, 2022, 05:41:51 AM
Brilliant - thanks ... I'll get one ordered
Simon
Post by: McCabe-Thiele (Ted) on September 21, 2022, 10:01:19 AM
Bearing in mind the flamability of petrol does anyone make a safe auxilliary fuel tank at a sensible price?
Any links or tipe welcome - something like this?
.https://www.ebay.co.uk/itm/314084385274
Post by: Sesman on September 21, 2022, 10:09:09 AM
I use the 20.99 one featured at the bottom of the page.
Post by: JamesH on September 21, 2022, 10:18:53 AM
I've used a couple of Sealey MS209's for years, and they're a decent bit of kit. Nice thing with this is you can extend the supply pipe slightly and hang the tank higher give the carbs a bit more 'static head' - good for making sure the float needles are definitely seated and not leaking...
https://www.ebay.co.uk/itm/191412318383
Post by: ST1100 on September 21, 2022, 11:41:06 AM
I got me this one:
https://www.ebay.co.uk/itm/144119166689?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20201210111451%26meid%3Db4d97602183f45739efb71409a343932%26pid%3D101196%26rk%3D1%26rkt%3D3%26sd%3D314084385274%26itm%3D144119166689%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithBBEV2bAndUBSourceDemotionWithUltimatelyBoughtOfCoviewV1&_trksid=p2047675.c101196.m2219&amdata=cksum%3A144119166689b4d97602183f45739efb71409a343932%7Cenc%3AAQAHAAABIIep8YrnpoI5Ip1Fr26ya5Zdwg2V78Yl01uYLsdPZcFTvxKxDts2M2LiSIpUM3yyPCg4I%252FI%252F%252BBr%252B3lbC%252BxYqInYGBmzIxc4EMw3YF0EDxTKylV0i0LGxhZWMUSxq4NtHDJNwgACD32uqufPPoZEI2JJH6Okagqhcyokc276tPGdVumKtPbAViVaR1EAVVxvF38P3m2FAf7akJVpNlDY2KKzNFHQFJGX%252BSp%252BPAlFO4pkIW97ZmkUT7cdld4MKuH%252FYymW2laD05ETH9OyzYkXORTG5%252BoF1qWj6EHdyCLr6ImBwet3rIcHTgLUpV%252F%252Fd1nMFte76ezWpQmiyRTCIAHqCPcJExSPcXEfmjkmtdXUWzEU1XJgTMToyrQj4T%252FmfmpAsmQ%253D%253D%7Campid%3APL_CLK%7Cclp%3A2047675
plus an IV-stand which the also holds the Carbtune
then a variation of those in 6 & 8mm so I can swap to various motorcycles
https://www.ebay.co.uk/itm/272616776005?hash=item3f7939e145:g:COoAAOSwX61ZB6e9&amdata=enc%3AAQAHAAAAsKaLJLZQ1NxD5GW5fJQig4oLiu2L8fmV9G7l%2F4Dttmj64rcLImt%2Bc9r5Z7X2NEHCktT%2BbtsrHKVq5FuYm%2BWTGyHH08UIMzXlq0CbYdIuWaUMFBHHJcnwp5KMCYo7zMIXF0hAVzARVtdmSkWA1QIbUs30GEiegUD3Xw5YYaM56C5CTUButbPATblUNHd7%2BAEhDcjIBZLUpWYF9vz79RPDr62jamm40EDs%2Bp1HacNjUo3f%7Ctkp%3ABk9SR9b2kfrrYA
Post by: Oddjob on September 21, 2022, 01:24:36 PM
I gather then James you use 2 reservoirs to feed the twin pipes instead of using a Y splitter?
Post by: deltarider on September 21, 2022, 04:30:41 PM
Why not strap the tank to the buddyseat and use extension tubes? You have to remove the tank anyway.
Post by: SPR on September 21, 2022, 08:13:09 PM
Knowing my luck I'd drop it !!!
Cheers everyone .... plan sorted so will hopefully get on it at the weekend
Simon
Post by: K2-K6 on September 21, 2022, 08:33:21 PM
For longer than I care to remember I've just stuck a plastic medical syringe of about 150ml into the existing feed pipes/s held vertical by stiff wire to nearest frame point.
Fill with fuel and that's enough to run for easily enough setup time.
Post by: JamesH on September 22, 2022, 12:24:14 PM
Lol - I lost one for a while, bought a replacement, then found the orginal.
