SOHC.co.uk Forums => CB750 => Topic started by: dukenewq on June 22, 2010, 09:08:01 PM
Title: CB750 K7 sump bolts
Post by: dukenewq on June 22, 2010, 09:08:01 PM
Hi there
I've managed to pick up a none runner 750 K7. The sump plate/cover is cracked and is off the bike, the bolts are also missing.
I've managed to find a replacement on eBay but again with no bolts.
Can anyone tell me what size the bolts are or where I can source them from?
cheers
Mark
Title: Re: CB750 K7 sump bolts
Post by: Sprunghub on June 22, 2010, 10:23:45 PM
http://www.cmsnl.com/honda-cb750k7-four-england_model14390/partslist/E12.html (http://www.cmsnl.com/honda-cb750k7-four-england_model14390/partslist/E12.html)
I use a Fixings supplier on the Local Trading Estate....having provided the sizes from the Fiche pages. At the prices quoted....probably as easy to get them from CMS or Silvers ?
Post by: dukenewq on June 22, 2010, 11:05:55 PM
Thanks Sprunghub
I notice you are in Tewkesbury, I'm over in Cheltenham. Would the local fixing supplier be Probolt on Northway Trading estate?
Post by: F2 Paul 876 on June 24, 2010, 07:09:44 PM
Hope this helps.
Post by: dukenewq on June 24, 2010, 08:27:40 PM
A huge help. Thank you everyone
cheers
Mark
Post by: Sprunghub on June 24, 2010, 10:33:56 PM
Thanks Sprunghub
Hi Mark - I use a Allfast.....they are indeed on Northway, sort of place where if you go in for 1 bolt, they often provide them 'gratis' once they know your face.
Doubtless you know about them already, but Mayday Bearings at Swindon Village - turn by Skellern's - or the Sex Shop dependent on your interests ! are the business for any seals or bearings.
+ there is Bryan on this Forum who is local to us at Gloucester who is the 'biz' for knowing "how to" & "how it should" all go together.
There's almost enough of us for a "Branch" now !
Post by: dukenewq on June 25, 2010, 10:32:44 PM
Sprunghub
Thank you for the information. I've been out tonight with the penetrating oil. So far every bolt I've soaked has started to loosen! I'm sure they aren't all going to be ok.
The sump from ebay arrived and is in good condition.
My plan is to strip the bike, remove and rebuild the engine, sandblast and powdercoat the frame as it is quite rough.
Some project but I'm not in a hurry!
Mark
