Other Stuff => Misc / Open => Topic started by: McCabe-Thiele (Ted) on November 11, 2022, 12:01:25 PM
Title: Best solvent for final cleaning prior to painting crank cases ?
Post by: McCabe-Thiele (Ted) on November 11, 2022, 12:01:25 PM
When I painted my 400 I brushed the crank casing surfaces with thinners, used clean absorbent paper to dab off any dirt that appeared then a final coat of thinners - when dry I Rattled Caned them - then air dried only. This time I plan to oven bake as per the paint instructions.
I have it in my mind that someone on this site mentioned using brake & clutch cleaning fluid instead  - I have a 5 litres can of that if it's better in some way ?
Title: Re: Best solvent for final cleaning prior to painting crank cases ?
Post by: Sesman on November 11, 2022, 12:16:03 PM
Acetone?
Post by: Bryanj on November 11, 2022, 12:45:58 PM
Should be ok ted as you already got it
Post by: gary123 on November 11, 2022, 01:16:14 PM
I had my cases acid dipped and then a used brake cleaner to remove any potential greasy fingerprints.
Post by: McCabe-Thiele (Ted) on November 11, 2022, 01:31:35 PM
I've also got Cellulose Thinners so looking for the best option.
I'm thinking Thinners has the lower flash point so may leave less residue?
Post by: Matt_Harrington on November 11, 2022, 04:15:29 PM
Acetone or Thinners are my choice....
Post by: heli_madken on November 11, 2022, 11:40:01 PM
Automotive panel wipe doesn't leave any residue behind and is made specifically for this task
