SOHC.co.uk Forums => Recommended Sources for Parts and Services => Topic started by: rigwit on July 08, 2010, 10:22:54 PM
Title: Got a prob with shafts pistons cams cranks etc etc
Post by: rigwit on July 08, 2010, 10:22:54 PM
Hindel reman of bradford are engine specialists  can make any size of plain bearing  -----  reclaim worn shafts--  got a crank that is out of hondas limit---- no problem for them they submerge weld the journals and then grind to whatever spec you need-same with cams and lobes-------  ive had dealings with them in the past regarding a cam you couldnt get anymore  and they did it no prob--  if they dont have the profile for it --it would help if it was given......  always  a way to keep the old stuff a going  direct link to reman service's
http://www.hindlereman.com/index.php?option=com_content&view=article&id=8&Itemid=3 (http://www.hindlereman.com/index.php?option=com_content&view=article&id=8&Itemid=3)
Title: Re: Got a prob with shafts pistons cams cranks etc etc
Post by: pae on July 09, 2010, 08:58:41 AM
That's an impressive set-up. Worth keeping their name for the future, thanks for the link.
Post by: Rozabikes Tim on July 09, 2010, 10:14:18 AM
S.E.P. at Kegworth, Liecestershire - just off J23 M1 do similar. I had crank done on a 400 superdream years ago. Think I have seen an ad recently in Classic Mechanics or Classic Bike.
Tim
