SOHC.co.uk Forums => CB500/550 => Topic started by: McCabe-Thiele (Ted) on May 19, 2023, 01:11:24 PM
Title: 500 oil guide B
Post by: McCabe-Thiele (Ted) on May 19, 2023, 01:11:24 PM
The oil guide is a bit out of shape at the end but otherwise seems useable - the earlier type 11203-323-000 is available but priced at a hefty £30.85 to order from DS.
My later engine number (CB500E-2010986) should have 11203-323-010 that appears to be  no longer available.
TBH I do not know what part I have it was retained in the old engine casing by the threaded bolt - manual shows a self taper 5x16 - my casing does not have a 5 mm thread so intend to fit  the correct  taper screw.
The guide looks as though it diverts oil to the main shaft needle roller bearing. Will I be okay to re-fit the oil guide - if not would the earlier part number fit?
'(https://live.staticflickr.com/65535/52909270959_00c5e15c55_c.jpg) (https://flic.kr/p/2oBpQVD)PXL_20230519_113027305 (https://flic.kr/p/2oBpQVD) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Title: Re: 500 oil guide B
Post by: Bryanj on May 19, 2023, 01:34:51 PM
The end number is usualy a supplier or minor mod so should be fine Ted
Post by: McCabe-Thiele (Ted) on May 19, 2023, 01:36:59 PM
Thanks Bryan.
Post by: Oddjob on May 19, 2023, 03:30:41 PM
If you need either Ted I have both of those, both oil guide and screw and yes it is like a self tapper.
Post by: McCabe-Thiele (Ted) on May 19, 2023, 08:00:39 PM
I have sent you a PM Ken
Post by: McCabe-Thiele (Ted) on June 13, 2023, 10:17:09 PM
I know the self tapper holds the guide - mine looked as though it was also glued on - Hondabond?
Post by: Oddjob on June 14, 2023, 12:16:22 AM
Nope, just the screw.
