SOHC.co.uk Forums => CB500/550 => Topic started by: deltarider on May 27, 2023, 09:55:39 AM
Title: What is this?
Post by: deltarider on May 27, 2023, 09:55:39 AM
In the garage bike fell over on its LH side and there is some damage.
The switch unit as a hole, 35200-341-600 is NA. The European CB500K2 shares this part with:
CB750K6 FOUR AUSTRALIA
CB750K6 FOUR ENGLAND
CB750K6 FOUR EUROPEAN DIRECT SALES
CB750K6 FOUR FRANCE
CB750K6 FOUR GENERAL EXPORT KPH MPH
CB750K6 FOUR GERMANY
Option 1 is to buy a complete repro for € 123,57 at Honda4.NL. https://honda4parts.nl/product_info.php?products_id=2621 Quality unkown and it involves a lot of labour.
Option two is to fit just another clutch handle. A friend has one for me.
Now my model has that mini switch that prevents starting when bike is in gear unless clutch is pulled. I like to keep it that way.
I've searched the garagefloor for eventual dropped parts and I found this little half moon. BTW, the black little thing in the same picture is possibly not from my bike (it probably was already there on the floor).
My question is: what is this little half moon shaped part from and is it possibly supposed to be in between the miniswitch and the clutch lever and, if so, how should it be oriented?
When I opt for the cheap option, there is still a new spot for the mirror to be found. Do you guys know of something I can fit around the steel of the handlebar which can accomodate my mirror. Not original, but I can live with that.
Title: Re: What is this?
Post by: McCabe-Thiele (Ted) on May 27, 2023, 10:37:31 AM
That unidentified part looks like a Woodruff key - I don't think Hondas have them.
Post by: Bryanj on May 27, 2023, 12:32:23 PM
And the other bit a hammer wedge
Post by: Bryanj on May 27, 2023, 12:34:41 PM
Also you can just fit a new lever blade and do without the mirror if that is legal where you are, im sure somebody  will be able to find either a used half switch or complete for you
Post by: Matt_Harrington on May 27, 2023, 01:44:36 PM
Once disassembled, I'm sure you could get the main body welded up....
Post by: deltarider on May 27, 2023, 03:07:04 PM
Thanks guys. The same friend that has the lever, also has a complete used original unit he is willing to sell, so that is the way I'd like to go which means I can just fit the mirror again where it belongs. It involves some work ofcourse. I have always managed to circumvent this through-the-handlebar replacing of wires chore, but I guess it's my turn now. Others did it, so it must be doable.
@ Bryanj. My model bike is still streetlegal without mirrors, but - to be honest - it's a bit risky imo. The bike looks much nicer without them and I was often tempted to ride withouth them. But nowadays my head/neck arrangement doesn't turn so easily anymore, so better to stay on the safe side.
@Matt. I am not sure the broken part can be welded again, but I'm no expert.
Oh and the mystery of that little half moon shaped thingy is solved. I remember now I've helped my neighbour some months ago fitting an EI on his '64 Puch MS50V and that we had to remove a wedge from his crank. We did this at the very same spot in the garage.
Post by: Oddjob on May 27, 2023, 03:19:35 PM
Actually they do Ted, there are 2 fitted to the 500/550 and most likely the other SOHCs as well.
Can you guess where they are?
Post by: Bryanj on May 27, 2023, 04:07:24 PM
Please sir can i gues cana cana
Post by: mickwinf on May 27, 2023, 04:26:39 PM
hmm dont know
Post by: Oddjob on May 27, 2023, 05:26:22 PM
No, you know where they are, that's cheating. If you didn't know I'd be more surprised
Post by: McCabe-Thiele (Ted) on May 27, 2023, 05:27:27 PM
Not ringing any bells with me must be somewhere that I have not taken apart  - two you say Ken go one where do they go?
Post by: Oddjob on May 27, 2023, 05:29:44 PM
They are fitted underneath the 2 lifter arms on the carb shaft, they key the lifter arms to the shaft so there is no chance of slippage.
Post by: Bryanj on May 27, 2023, 07:11:42 PM
But they are way smaller than the one in the pic!
Post by: deltarider on May 28, 2023, 08:49:18 AM
I'm afraid my info above was not a 100% accurate. The parts list shows the clutch switch cable is not an integral part of the complete unit, but a part that can be separetely ordered. In Hondaspeak: SWITCH ASSY., CLUTCH LEVER. It's #6 in the pic. https://images.cmsnl.com/img/partslists/honda-cb500k2-general-export-f-3-handle-lever-switch-cable_big3IMG01171125_2021.gif
Question: what is the black/yellow wire on Honda's for?
Post by: Bryanj on May 28, 2023, 10:17:59 AM
Black/Yellow is a lighting wire from memory but you cant rely on the wire colours of that switch as the front brake light switch on the small drum braked bikes(up to 125ish) is the same fit with different colours and there was a time when clutch switches were in short supply so brake ones got fitted
Post by: Seabeowner on May 28, 2023, 07:16:19 PM
Think black/yellow is the +12v lighting feed to the dipswitch.
Post by: deltarider on May 28, 2023, 09:32:28 PM
The reason I ask: my model does not have a black/yellow wire, but the repro '35200-341-600's do.
Post by: Bryanj on May 28, 2023, 09:37:02 PM
Thats probably because the us have lights on with ignition whilst uk has a lights on off switch
