SOHC.co.uk Forums => CB350/400 => Topic started by: 4wDaz on July 07, 2023, 02:01:11 PM
Title: Starter reduction gear
Post by: 4wDaz on July 07, 2023, 02:01:11 PM
Can anyone confirm if it's possible to change the starter reduction gear without splitting the cases? (400/4). I don’t think it can but a customer of mine insists it can be done by just removing the sump, having never tried to do it this way I'm only 99% sure it can't but appreciate any comments
Cheers Daz
Title: Re: Starter reduction gear
Post by: Bryanj on July 07, 2023, 02:15:10 PM
Depends if there is room to get the shaft out and how mechanical your pet spider is
Post by: McCabe-Thiele (Ted) on July 07, 2023, 02:26:24 PM
If it is possible, a course in Practical Gynaecology is a baseline - I would imagine taking the engine out & inverting it would be the operating position.
Begs the question why does it need replacement and where have the missing metal parts gone if its worn?
Post by: 4wDaz on July 07, 2023, 02:39:23 PM
He reckons it can be done without removing the engine, so not only do you have to be a contortionist you now have to do the job lying on your back.  :o :D
Post by: Nurse Julie on July 07, 2023, 02:44:02 PM
If he knows so much about it, why isn't he doing it himself 🤣😏🤣🤣
Post by: 4wDaz on July 07, 2023, 03:10:09 PM
;D I know i won't be attempting it  ;)
Post by: Herr Supersport on July 11, 2023, 01:24:52 PM
Maybe this helps - or shows the way. Attention, it is a 550:
http://forums.sohc4.net/index.php/topic,122084.0.html#lastPost
Personally I wouldn't like to go this route. Shure you can wallpaper the entrance through the letterbox but who want's that?
Post by: 4wDaz on July 11, 2023, 02:10:16 PM
Thanks for that, is the 550 engine similar to the 400 apart from the cc ?
Post by: McCabe-Thiele (Ted) on July 11, 2023, 02:20:39 PM
I am pretty sure the sump on a 400 is smaller in terms of length & width so the aperture you are working in will be smaller as a result.
IIRC the 400 sump is a tad deeper.
Post by: 4wDaz on July 11, 2023, 02:27:18 PM
I wish him luck  ;D
