SOHC.co.uk Forums => CB500/550 => Topic started by: Mcraig1982 on July 08, 2023, 10:20:26 AM
Title: speedo adapter plate
Post by: Mcraig1982 on July 08, 2023, 10:20:26 AM
(http://)
Any where in the uk sell these? postage is £££££
Title: Re: speedo adapter plate
Post by: Trigger on July 08, 2023, 10:25:42 AM
Only ever seen them forsale in Germany  ;)
Post by: Bryanj on July 08, 2023, 10:30:38 AM
If you want twin disc it may be possible to modify your original drive plate depending on the front hub. Does the hub have two flats on it
Post by: Trigger on July 08, 2023, 10:31:51 AM
(http://)
Not a bad price. The one i bought was from the UK and that was £45  ;)
Post by: Mcraig1982 on July 08, 2023, 10:34:16 AM
Ive not had a proper look yet & I don't have the facilities to chop the original one down properly. Id rather buy a properly made plate.
The one from Germany looks well made, just costly postage  :-[
Post by: Bryanj on July 08, 2023, 10:41:19 AM
I modified a plate with a vice, hacksaw and file
Post by: Nurse Julie on July 08, 2023, 10:58:05 AM
Is it for a 500 or 550?
Post by: Mcraig1982 on July 08, 2023, 11:02:21 AM
76 500
I think the 500 & 550 are the same ?
Post by: Nurse Julie on July 08, 2023, 11:05:44 AM
76 500
The forks are different, there is no fitting point for a 2nd caliper arm on the 500 forks. They are completely different forks.
Post by: Mcraig1982 on July 08, 2023, 11:23:03 AM
oh really? it looks like it has the bracket on the right side fork leg??
Post by: McCabe-Thiele (Ted) on July 08, 2023, 12:21:16 PM
Not able to zoom in on your right fork leg - if it has a calliper mounting point it should be a mirror image of the left side fork bolt lugs - four in total iirc.
Two top ones that hold fender & top arm pivot, large lower bolt, caliper adjustment bolt hole.
It depends what lower legs have been fitted.
Post by: Bryanj on July 08, 2023, 01:32:15 PM
Thats because its nothing like a standard 500, probably 550 forks, and riding without a mudguard/fork brace is asking for handling problems
Post by: Mcraig1982 on July 08, 2023, 02:55:36 PM
? rides fine. Plus it never rains in the uk  ;D
Post by: Bryanj on July 08, 2023, 06:03:24 PM
Wait till you hit a bump in a corner, without the brace the forks flex every which way
Post by: robvangulik on July 08, 2023, 08:20:14 PM
With that size front tyre handling won't be too good anyway :o
And the speedo will read too (s)low as well...
Post by: Mcraig1982 on July 09, 2023, 07:08:21 PM
Making progression
Post by: Bryanj on July 09, 2023, 08:27:16 PM
I can give you a pic of how to modify the plate as long as you have the two flat type hub
Post by: Mcraig1982 on July 10, 2023, 01:05:34 AM
Please  :)
Post by: Mcraig1982 on July 10, 2023, 06:49:41 PM
Does anyone know if the brake banjo is 10 x 1.0 or 10 x 1.25 thread ?
Post by: Trigger on July 10, 2023, 07:05:26 PM
All Honda Banjo bolts are 1.25 pitch  ;)
Post by: Mcraig1982 on July 10, 2023, 07:41:41 PM
Thanks pal
