SOHC.co.uk Forums => Recommended Sources for Parts and Services => Topic started by: davidcumbria on July 23, 2023, 10:01:35 AM
Title: Bright zinc plating
Post by: davidcumbria on July 23, 2023, 10:01:35 AM
Hello,
Any recommendations for Bzp plating various nuts bolts collars small plates etc in my 550k rebuild,  never done this before. . I am based in south Cumbria but will probably end up posting so a post in post out service anywhere in the uk would work.  Price and experience info would be appreciated. Many thanks David
Title: Re: Bright zinc plating
Post by: Lobo on July 23, 2023, 03:03:26 PM
Hi Dave.
Having done a full resto last year on my ‘750 K2 I was too faced with this problem. I’m no longer in the UK (ie Oz), but quickly learned that commercially / small plating amounts was a problem - so much so that I was essentially forced into doing my own Zinc platings. Did I enjoy it - nope. An awful lot of prep and fussing. Cheap? Erm, reasonable. Results? - fine, but only with great prep and a quality kit.
So - it all got done, to an acceptable quality, and included such refinements as gold passivating.
Not advocating home plating; but saying it’s certainly doable if you’ve the inclination.
Post by: davidcumbria on July 23, 2023, 11:29:11 PM
Thanks Lobo. Doing it myself is a last resort. Hopefully some people on here will be able to share the name of a supplier they used for their bolts etc…….
Post by: Arch stanton on July 24, 2023, 10:50:08 AM
I believe there is a place in Lancaster.
