SOHC.co.uk Forums => CB500/550 => Topic started by: PikeyBoy on July 24, 2010, 08:57:05 PM
Title: Primary drive chain backlash/play
Post by: PikeyBoy on July 24, 2010, 08:57:05 PM
Well at last I am getting on with the rebuild.
I have today taken the clutch assembly off and noticed that when I turn the primary drive shaft there seems to be a lot of backlash/play in the primary drive chain.
Is there a tensioner on the chain somewhere or do I possibly just need to get a new chain?
Title: Re: Primary drive chain backlash/play
Post by: lordwhimsey on July 24, 2010, 09:49:46 PM
There's no tensioner on the primary chain; if you're taking everything apart it's worth changing it although they're a bit pricey (
Post by: Bryanj on July 25, 2010, 09:31:24 AM
The primary can wear through both the oil gallery from pump to filter AND the main cross gallery so if you have plans to split the cases always fit a new one
Post by: Yoshi823 on July 30, 2010, 05:52:07 PM
It's a Hy-vo multi link chain & i've heard of engines with 80,000+ miles on them with no noise from the bottom end. The chain can sound as though it's flapping around if the carbs are out of synch.
