SOHC.co.uk Forums => CB500/550 => Topic started by: deltarider on August 01, 2023, 10:09:27 AM
Title: Those upper vent tubes on our carbs... why are they there?
Post by: deltarider on August 01, 2023, 10:09:27 AM
Never quite understood why those upper vent tubes are there. Yes, they vent, but so do the overflow tubes.
Title: Re: Those upper vent tubes on our carbs... why are they there?
Post by: K2-K6 on August 01, 2023, 11:03:33 AM
The overflow is specifically to allow excessive fuel, from leaking intake fail, to bleed out safely (well from not depositing into engine etc) away from other parts of the bike unimpeded.
You wouldn't want the carbs to suck air from that tube ideally, possibly water etc has access.
Vent tubes allow "safe" ingress of air from discreet source, in or out, to make sure there's no pressure plus or negative allowed to accumulate in float bowl, making them as near neutral as possible so that the vacuum through the carb venturi and pulled through the jets is absolutely as repeatable as possible to give consistency in jetting/mixture.
Post by: McCabe-Thiele (Ted) on August 01, 2023, 11:14:26 AM
Interesting explanation k2-K6 makes total sense when you put it so succinctly.
Post by: deltarider on August 01, 2023, 11:28:09 AM
Where should their open ends ideally be? Saw a video recently where the owner of a CB500 had lead them between the airfiltercase and the battery. See: 10:16 https://www.youtube.com/watch?v=lkxVVq_o8mY
Post by: K2-K6 on August 01, 2023, 01:08:55 PM
Likely anywhere that gives a air supply without risk, something near the airbox intake itself mid bike and away from rain etc  looks most sensible.
You wouldn't want them to be influenced by air intake vacuum though, so not directly in the intake mouth for example.
Post by: deltarider on August 01, 2023, 05:26:36 PM
AFIK mine have been dangling in more or less the same spot where the exits of the four overflow tubes are. Hence my question. :)
Post by: Erny on August 05, 2023, 09:39:32 PM
mine goes back to top of the battery area
Post by: deltarider on August 22, 2025, 04:23:10 PM
Please read: http://forums.sohc4.net/index.php/topic,205679.0.html
Post by: deltarider on August 23, 2025, 04:50:23 PM
Come on guys! Who has a bank of CB500 carbs on the bench and can verify this situation?
Post by: McCabe-Thiele (Ted) on August 23, 2025, 08:27:20 PM
Does this help?
#(https://live.staticflickr.com/65535/54738897027_53aaabe460_b.jpg) (https://flic.kr/p/2rp6a1F).trashed-1699798592-PXL_20230917_174014528 (https://flic.kr/p/2rp6a1F) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
#(https://live.staticflickr.com/65535/54740059798_b494462fe1_b.jpg) (https://flic.kr/p/2rpc7Es).trashed-1699798575-PXL_20230917_174035269.ACTION_PAN (https://flic.kr/p/2rpc7Es) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Post by: Nurse Julie on August 23, 2025, 09:33:19 PM
They go up over the plenum chamber and hang down.
Post by: deltarider on August 24, 2025, 06:47:30 AM
Thank you for the pics, but I have discovered something very strange. Please read: http://forums.sohc4.net/index.php/topic,205679.0.html
Post by: taysidedragon on August 26, 2025, 01:28:11 PM
I read all the posts on both forums. I think you've discovered how the float chambers are connected now.
To answer your original question of "why are the 2 vent tubes there?" my theory is that they provide a secondary source of air vent. If the carbs are overflowing then the overflow tubes are full of liquid fuel and no air can pass through them. Air can still pass through the vent tubes though.
Post by: K2-K6 on August 26, 2025, 02:59:30 PM
My understanding of the tubes and their need to be there in the design is for mitigation in "anti-syphon" function.
I may he wrong on this, but I don't see the aeration/emulsion performance drawing air from float bowl (as mentioned on US site) in carburettors generally.
This is usually discreet in that air to float bowl is purely supplied to maintain as close to atmospheric pressure on the fuel content only, this to give the supply effect when vacuum is imparted on the jets by depression through the venturi. in reality, the air volume in a float chamber doesn't get changed much at all during use .... the outflow through the jets is exceeded by the capacity of flow from the main fuel tank (modulated by float valve) to always replace what is being used immediately. The air in reality is vented to stop this fuel flow action be impeded by artificial pressure shift, it's literally "shuffling" back and forth (the air that is) to accommodate any system lag in supply and use. The air in there is not being consumed.
The emulsifying air is, as I understand it, a separate supply route and usually "tapped" from entrance side of carb slide areas  .... ultimately to be modulated by it's own jet or adjustment of air only to give mixture option in setup.
The fuel jets always being intended to have their entrances below the fuel level (in correct operation) would appear to vindicate this.
Its also not true that cars with common manifold over multi cylinders use CV type carbs exclusively because of this.  Many manufacturers have produced their design without using CV type carburation.
Post by: Oddjob on August 27, 2025, 12:43:22 PM
Fairly sure I remember a post by Mark Paris saying the vent tubes work best if positioned in the still air near the filter housing. So up, over the plenum chamber and down each side of the filter housing. Maybe tape them in position so they can’t fall down over time.
Post by: K2-K6 on August 28, 2025, 01:39:15 PM
I believe the theories being offered about absolute airflow and it's effect on jetting at various rpm range is based on false premise.
The vents present in these carburettor (any carburettor, in reality) feeding the float chamber, don't contribute to the air supply consumption of the engine.
Effectively, the "main" route through float bowl standpipe is to supply method of maintaining atmospheric pressure conditions inside the bowl. Secondary function to act as weir type overflow should the feed valve become impaired. The long tail pipe is really a courtesy to avoid spilling fuel onto the engine in this eventually, also to alert you easily via the puddle it make on the ground, to the failure of the carburettor float valve.
Its not a constant flow of air through and into the chamber. It goes back and forth in very small amounts based on system response in filling the chamber with fuel  .... this to specifically avoid a pressure shift and hence disturb the overall jetting balance.
ALL fuel total consumed by exit through the jet is immediately replaced by exact volume of fuel coming in from fuel tank, else the notionally set float height would vary too much. The vent just allows free flow of this action. It's not a supply route in itself.
Should there be a failure in blocking or impeeding this function, then the carburettor COULD pull vacuum on that overflow pipe. The auxiliary vent should prevent that eventuality by providing a leak, as such. There's also no filtration fitted to these tubes, making it potentially problematic to "syphon" through any of them.
Like the Honda second/return throttle cable, like separate brake circuit on vehicles, they'd not often be called into use .... but they are fitted anyway. It's a responsibility in production design to cover unseen events in normal use.
The two vents should not exit at the same place if its to avoid a syphon risk. Neither should any of them be subject to pressure (positive or negative) as that would influence float bowl neutrality in parity with ambient atmospheric  ... ultimately to influence jetting against manifold depression, which would shift mixture uncontrollably.
Post by: Oddjob on August 28, 2025, 01:53:38 PM
One day Nigel you’ll do a reply that doesn’t make my brain hurt😁😁😁😁😁
