SOHC.co.uk Forums => CB350/400 => Topic started by: Matt_Harrington on August 07, 2023, 10:01:48 AM
Title: 400 primary drive cush rubber
Post by: Matt_Harrington on August 07, 2023, 10:01:48 AM
Does one apply any grease (maybe assembly lube?) to these to assist fitment or just a good dollop of oil?
Title: Re: 400 primary drive cush rubber
Post by: Bryanj on August 07, 2023, 10:28:57 AM
Always fitted them dry
Post by: McCabe-Thiele (Ted) on August 07, 2023, 10:32:13 AM
I did mine dry but used a cable tie to keep them in place - then when only the cable tie was stopping it going all the way removed it - worked a treat.
Post by: Matt_Harrington on August 07, 2023, 11:03:17 AM
Thanks chaps - should have the cases back together this afternoon then I will have a bit of free bench space!!
I must admit that I spent hours trying to get the gears to work. Lined up and installed in neutral with selectors in correct position but could not actually find neutral. No matter what I did, no joy - until I realised the 41T gear on the countershaft was the wrong way round - then all was happy! Hey Ho....
Post by: McCabe-Thiele (Ted) on August 07, 2023, 11:12:27 AM
I'm paranoid about taking gear shafts to pieces I photograph the item as I remove the parts then do a written description. 🥱🥱🥱
Then I forget when taking off the kick start as it looks so straight forward. 👎👎👎
