SOHC.co.uk Forums => SOHC Singles & Twins => Topic started by: MIJTEC on November 24, 2023, 11:42:47 AM
Title: Head scratching here - running very rich after float adjustment ! CB125s
Post by: MIJTEC on November 24, 2023, 11:42:47 AM
Hi everyone....can do with some advice please ! I am new to working on old bikes but have exhausted all ideas before reaching out to you :)
Picked up a 1975 cb125s recently and after some basic checks and service the bike started. Was running a bit rough but would start by the second kick. All great so far so I thought lets fine tune this further. I purchased a Float level tool to adjust the float height to spec but now its way off the mark when I start it. I'm getting some white smoke and the bike stalls after a minute as the spark plug is totally coked up....it clearly running too rich but I can't see how my minor tweak can make such a difference ? Is there something else I can check that I have missed ? Seems the float height is very sensitive and I cannot get it back to a running condition...or is it coincidently another issue as it was not touched for a few weeks.
Before my clever intervention I had done the following (and the bike was running).
New battery, points and clearance gap set. New spark plug (gap set), oil and air filter, new fuel lines, New petcock and importantly a thorough manual clean of the carb. It was a manual clean with lots of elbow grease and carb spray. I replaced the main jet. All small clearance holes are visible and I've double checked that too. It looks clean as a whistle ?
I am sure this has been asked before (sorry) but can anyone confirm please where the distance should be taken from to measure the float height ? The manual only says carb body but many videos and info online are contradicting this. Some say the gasket seal face which is much further down and the carb body top face which is is higher ? I have taken it from the small notch face on the side of the body up to the top of the float. Spec is 24mm according to the manual. I ensued the float is just touching the float valve spring and not compressing it as advised...please see pics below...looks 24mm to me.. :-\
Also the carb air/fuel screw and idle screw are set to factory conditions. On the air/fuel I have 1.5 turns out from the bottom.
Any other advice/checks to make are welcome....many thanks in advance.
Title: Re: Head scratching here - running very rich after float adjustment ! CB125s
Post by: K2-K6 on November 24, 2023, 12:14:50 PM
A very crude observation here...but the float looks very high if I'm seeing that picture correctly.
Evidenced by the "tide" mark on float that looks like its been previously running at a very different angle to how it's now being measured.
Equally crude, rough and ready set method....hold the carb up such that the float is hanging from its pivot vertically downward, then set the height with the tang so that when you tilt the assembly slightly such that the float is resting in its closed position on the valve, that the tide mark/waist line on the float is parallel with the float bowl gasket face.
This is how I set them when lacking good information or to just get them going if no other method available.
Then try running.
Post by: K2-K6 on November 24, 2023, 12:28:30 PM
To clarify......perhaps  :)
That seam line halfway up the circular float side, use that as measurement reference for your mm setting point and it should then look more logical.
Post by: McCabe-Thiele (Ted) on November 24, 2023, 04:08:48 PM
Probably stating the obvious but is the new main jet stamped with the same size as the original.
Replacement brassware is often not as good as the Honda original.
Post by: Oddjob on November 24, 2023, 04:25:11 PM
I'd mirror that comment but the main jet still looks original, the float valve and idle jet however don't. Aftermarket float jets and seat are well known not to seal as good as original brassware, try connecting a source of petrol to the inlet pipe and see if it actually cuts the petrol off when the floats set at 24mm.
Post by: MIJTEC on November 24, 2023, 04:54:24 PM
Thanks all for the quick replies and suggestions so far.
The main jet is the original but yes I did replace the float valve and idle jet from a new kit. Initially I could not get to clear (see the light) the small hole running through the pin (even after days of soaking) so thought to replace from a kit and did the float valve too. Maybe I should put the originals back in (did finally manage to clear the idle jet yesterday ). Maybe time to invest in a small ultrasonic cleaner...I'll start to drop the Christmas present hints at home....
On the adjustment side, the seam line as a guide seems a good starting point and of course also a great shout with simulating with actual fuel at 24mm. Ill give that a shot and let you know !
thanks again all.
