SOHC.co.uk Forums => CB350/400 => Topic started by: colin400four on September 03, 2010, 07:25:33 PM
Hi to all,
as you all know to try and find a new rear sprocket with an original gaurd fitted for the 400/4 is pretty difficult, so I came about this " used Sprocket " which looked like it had plenty of life left in it, but still classed as usedand tatty, SO, out came the paint and I "tarted " up the sprocket and guard.
Not bad I thought, but still a niggling thought that no matter what I did it was always going to be a used Sprocket.......... see first set of pics.
So, plan 2, get a new after market spocket, an old guard, restore the old guard and then rivet the gaurd to the new sprocket, Looks o.k and now with a new sprocket :D see second set of pics
COLIN.
and these
Superb bit of work there welldone
pete
Yep, all looks Brand New!
Looks good.
How did you rivet it up without chipping the paint?
Thans for the kind remarks,
With regards to the rivets, I had to use 5x16 mm rivets, big buggers, which on a test piece broke my crap cheepo pop rivet gun, didn't help I guess as I was asking the gun to "pop" a size it was not made for , so I invested in a big bad lazy tongue pop riveter and this did the job with no problems.
With regards to chipping the paint, the way that you insert / pop the rivet, all the force seems to be taken on the actual rivet face , and the way you use a lazy tongue riveter as apposed to the little hand held riveters gave a much easier way to pop the rivet, (didn't need as much force ) so chipping was not a problem.
COLIN.
