SOHC.co.uk Forums => CB500/550 => Topic started by: Johnny4428 on March 06, 2024, 09:10:21 PM
Title: Will it fix?
Post by: Johnny4428 on March 06, 2024, 09:10:21 PM
Going to fit a new seal in this today but dissapointed to find this tacho drive broken. What’s the chances of a repair? Nothing to lose.
Title: Re: Will it fix?
Post by: Johnwebley on March 06, 2024, 09:41:44 PM
I don't know,
I would clean both joint surfaces with brake cleaner,
Use a good adhesive, something that lists metal,
Apply to break as per instructions,
Leave in a warm place and see what happens,
There is hardly any load on it,
If it does stick, you might want to reinforce by drilling tiny holes down through the break, fill the holes with glue and push small pins in the holes,
Post by: McCabe-Thiele (Ted) on March 06, 2024, 10:13:46 PM
That JB Weld is pretty good.
Post by: Bryanj on March 06, 2024, 10:35:13 PM
They are available pattern but sit down before you check the price, all 500,550 are the same
Post by: Johnny4428 on March 07, 2024, 10:24:32 AM
Already checked Bryan!😳
Post by: Johnny4428 on March 07, 2024, 10:28:28 AM
Thanks guys for replies,  I think I might buy a replacement yet as I need one for the other engine anyway, depending what route I go for tacho/speedo set up. So I have nothing to lose by trying a repair.
Post by: SteveW on March 07, 2024, 10:43:34 AM
I think Nurse Julie had a couple of these for sale recently.
Post by: Johnny4428 on March 07, 2024, 10:56:21 AM
Thanks Steve, I will send a message to her.
Post by: Orcade-Ian on March 07, 2024, 10:58:20 AM
Hi Johnny,
I'm definitely with John Webley on that one.  Some pinned reinforcement if there's space and original Araldite - not rapid version.  Leave to harden as said, somewhere warm for a few days (and then go back and collect the pieces 🙈). No, seriously it's worth a try.
Ian
Post by: Laverdaroo on March 07, 2024, 11:01:39 AM
Just for info, I’m currently looking into getting some made, we’ve a blank being offered soon from a pattern one that was submitted to a chsp abwhilevago. Not sure on time lines but it sounds promising.
Just so you know.
Post by: Johnny4428 on March 07, 2024, 11:03:35 AM
Yes thanks Ian, it’s a good shout indeed from John. I think I might even have some of that stuff, I’ll check to see if it is the rapid stuff or not. Thanks
Post by: McCabe-Thiele (Ted) on March 07, 2024, 11:05:17 AM
Just so you know.
Bloody hell Roo is this an Anagram  "chsp abwhilevago"
Post by: Johnny4428 on March 07, 2024, 11:05:45 AM
Just so you know.
Thanks Roo. That’s interesting, especially if they can make them for less than £100. Keep me posted!
Post by: Johnny4428 on March 07, 2024, 11:06:42 AM
Just so you know.
Took me a wee while Ted, I got it eventually.🤪
Post by: McCabe-Thiele (Ted) on March 07, 2024, 11:11:32 AM
Something (chsp)  a while ago ?
Post by: Johnny4428 on March 07, 2024, 11:15:40 AM
Chap.
Post by: McCabe-Thiele (Ted) on March 07, 2024, 11:17:18 AM
You must be good at Quizes & Cryptic Crosswords Johnny.
Post by: Johnny4428 on March 07, 2024, 11:19:18 AM
😂 not sure what it says about me the fact that I understand double Dutch!🤣
Post by: McCabe-Thiele (Ted) on March 07, 2024, 11:21:19 AM
What you need is a Babel Fish in your ear. (HHGTTG)
Post by: Bryanj on March 07, 2024, 11:27:46 AM
Or a universal translator ST,THG,V
Post by: Laverda Dave on March 07, 2024, 11:31:55 AM
All great suggestions Johnny especially if Roo's getting some made.
If you send the part to me I could take it to Brian, the guy who does alloy welding for me. He may be able to weld it although obviously as it's cast there will be no guarantee it will be successful and you may get a blob of alloy in return but if all else fails and you need it urgently there's nothing to loose.
I'm going over to Brian in the next few weeks to get a part for the poxy Triton altered.
Post by: McCabe-Thiele (Ted) on March 07, 2024, 11:36:05 AM
I'm a Douglas Adams fan - never really got into Star Trek Films - the first TV series was my era.
Post by: Laverdaroo on March 07, 2024, 11:42:13 AM
Soz bout that, hurriedly typing whilst dashing about
Soon as I know I’ll let you know, not sure yet but he’s doing one in brass first to see if it’s doable rather than casting. Not sure if it’s economical or not but I’ve got one lurking somewhere if you need one, I’ll have a look later as in the shed of dreams putting the thermostat on the VFR.
Post by: Laverdaroo on March 07, 2024, 11:42:36 AM
Babel fish
Post by: K2-K6 on March 07, 2024, 11:58:16 AM
I'd favour this as most likely to succeed, soak in solvent first then ultrasonic clean would have good chance of cleaning it and avoid contaminated structure to weld.
Always a risk of course until the welder can attempt decent trial.
Can be done, worthwhile to at least have a go.
Manufacturing one, Duralamin would be my first choice from a machining and final materials specification.
Post by: McCabe-Thiele (Ted) on March 07, 2024, 12:00:46 PM
Reminds me of the old translation joke.
If you translate the expression "Out of sight - out of mind" into Russian then have the Russian translation changed back into English you end up with "Disappearing Lunatic".
Post by: Johnny4428 on March 07, 2024, 06:04:56 PM
Thanks all for advice regarding repair. Nigel good advice on cleaning etc, unfortunately I don’t have an ultrasonic cleaner but will give it a good clean with brush and maybe acetone or thinners.
But I must add that I have a used one on the way thanks to NJ AND T. Takes the pressure off the repair job, but will still be perusing a repair on the broken one.
Post by: SteveW on March 07, 2024, 07:07:56 PM
What about the low temp aluminium brazing rods on eBay?
I’ve used them before and they are pretty good.
Post by: Johnny4428 on March 07, 2024, 09:48:59 PM
That’s a good shout Steve, I actually bought some of them a year or so ago but haven’t used them still. There’s probably not many degrees separating melting the repair rods and melting the housing though.😳
Post by: Laverda Dave on March 07, 2024, 10:44:51 PM
It's the degree of fear Johnny. Oh I'll give it a little bit more heat.......pop😢.
Worth a try though if you have them anyway and you have a spare on the way and hopefully Roo will go into full mass production with his new ones👍
Post by: heliwilly on March 08, 2024, 06:33:54 AM
The go to guy around here who can weld any metal especially alloys is Badfoot Customs. Check out his Facebook page, a metal genius.
Post by: Orcade-Ian on March 08, 2024, 07:29:10 AM
Only just re-read one of your posts Johnny, I have an ultrasonic bath if you want to go down that road first.  That might stop you being able to have it welded later though if it fails.
Shout if you need it.
Ian
Post by: Johnny4428 on March 08, 2024, 07:56:13 AM
Just checked out Facebook, that’s some impressive repairs!
Post by: Johnny4428 on March 08, 2024, 07:59:46 AM
Ian
Thanks Ian!
Post by: Johnny4428 on March 12, 2024, 12:47:11 PM
Glued and left for a few days to dry then made a steel band to glue round the flange. Now leaving to dry for a few days again.
Post by: McCabe-Thiele (Ted) on March 12, 2024, 12:56:57 PM
Unless I've missed it what "Glue" did you use Johnny?
Post by: Johnny4428 on March 12, 2024, 07:34:06 PM
Just the normal Arldite Ted, not the rapid stuff, as recommended.
