SOHC.co.uk Forums => CB500/550 => Topic started by: DomP on March 14, 2024, 05:45:17 PM
Title: 550 indicator relay
Post by: DomP on March 14, 2024, 05:45:17 PM
I've bought a new 2 pin led relay for my 550 but to my surprise the one fitted to my bike is a 3 pin, I thought they were all 2 pin?
Title: Re: 550 indicator relay
Post by: Nurse Julie on March 14, 2024, 05:47:41 PM
No, originals are 3 pin, modern day replacements are 2 pin. Just leave the green earth wire unattached.
Post by: DomP on March 14, 2024, 06:19:13 PM
Ah thanks Julie!  I've said it before but electrics is not my strong point...pure witchcraft
Post by: McCabe-Thiele (Ted) on March 14, 2024, 06:42:34 PM
IIRC you need to connect the remaining two wires the right way round as the terminal markings might be different.
I seem to recall having to reverse the two wires to get mine working - if its an electronic unit you can blow some units with the wrong polarity - worth checking the markings carefully.
With the 2-pin units they fit Positive & Negative earth vehicles  hence the need to check.
Post by: K2-K6 on March 14, 2024, 06:49:35 PM
Some of the cars still use 3 pin.
VAG (volks audi etc) relay "191" is such a beast.
Post by: K2-K6 on March 14, 2024, 07:01:10 PM
Can be bought here https://www.autodoc.co.uk/maxgear/9813662  :)
Post by: DomP on March 14, 2024, 09:58:38 PM
Mine were marked thankfully so an easy job, my cheap LED Ebay indicators work nicely too.
