SOHC.co.uk Forums => CB500/550 => Topic started by: martin_uk on April 11, 2024, 09:17:17 PM
Title: 1975 CB500K1 Engine reassembly in frame?
Post by: martin_uk on April 11, 2024, 09:17:17 PM
Started to reassemble my CB500K1 engine and finding just the bottom end quite a lump to handle.
I wanted to double check that it is possible to reassemble everything in the frame once the crank case halves are together and installed and whether anyone else has tried.
I have a motorbike lift which means it is easier to work on at comfortable height.
I have rebuilt a number of CB750 sohc engines and no option other than to assemble up to cam cover, but I was a few years younger then  :D
Title: Re: 1975 CB500K1 Engine reassembly in frame?
Post by: Nurse Julie on April 11, 2024, 09:31:25 PM
Yes, it is easy to build up in the frame. Plenty of clearance available between top of breather cover and frame, unlike the 750's.
Post by: martin_uk on April 11, 2024, 09:42:34 PM
Thanks Julie
Post by: McCabe-Thiele (Ted) on April 11, 2024, 11:07:53 PM
Make sure you leave the sump & oil filter off off it's pretty maneagable just as the crankcase halves, plenty of space to fit the block upwards afterwards.
I used a piece of cardboard in the shape of the sump held in place with a couple of bolts to keep the dog hairs out until I fitted the sump etc.
Post by: martin_uk on April 12, 2024, 12:29:38 PM
Thanks Ted
