SOHC.co.uk Forums => CB500/550 => Topic started by: neat street on May 25, 2024, 10:08:00 AM
Title: CB500 cylinder studs
Post by: neat street on May 25, 2024, 10:08:00 AM
Hi all, I am after 2 x cylinder studs for my CB500 and can`t find any anywhere? does anyone know of or has a couple that they would sell please.
#thank you
Title: Re: CB500 cylinder studs
Post by: neat street on May 26, 2024, 08:57:05 AM
to be clearer, its the front ones part No 90034-323-005 (approx 13cm long), these are a little shorter than the rear ones :-)
thank you
Post by: Bryanj on May 26, 2024, 12:36:57 PM
550 are the same, they are a swine to remove and i do have one of those in bits, i will try and get some out next weekend
Post by: neat street on May 27, 2024, 08:39:26 AM
Thank you Brian, the two in mine are broke and have to remove them, so far with welding nuts on, no joy, will leave them in soak for a week before I try again, realy appreciate your help..
Post by: neat street on June 03, 2024, 11:31:21 AM
managed to get both damaged studs out, and was not an easy task. welding was the only way for these two. one was right down to the end and welded a nut after leaving in soak of WD40 for a week, the other being longer also had the soak, but welded a longer strip of metal all the way down to the base giving more chance  it would hold, and this one came out easier :-)
Post by: Bryanj on June 03, 2024, 12:06:15 PM
My dearly beloved wanted a patio extension so havent had time to go in garage and get studs for you yet, it is on my list though
Post by: neat street on June 04, 2024, 06:21:49 AM
Thank you Brian, no problem, and family should always come first, no matter what :-)
Post by: Bryanj on June 08, 2024, 04:00:10 PM
I now have 2 front(short) studs removed and in a jiffy bag, pm me your details and we will agree how much!
Post by: neat street on June 09, 2024, 09:12:06 AM
Thank you Brian
realy apreciate your time and help :-)
pm sent, paypal OK?
best wishes and thanks again
John
