SOHC.co.uk Forums => SOHC Singles & Twins => Topic started by: RGP750 on June 13, 2024, 05:23:59 PM
Title: carb measuring
Post by: RGP750 on June 13, 2024, 05:23:59 PM
HiAll
I'm rebuilding a 1971 cb125 twin and it should have 18 carbs (not literally) I have got my 20 carbs mixed up with them.
I believe the 18 and 20 is the choke size in MM .
where should I be measuring? is it the width through the inlet?
Cheers Rich
Title: Re: carb measuring
Post by: Johnwebley on June 13, 2024, 05:35:00 PM
Normally it's the height,
On the CB200 the venturi is narrow, but the full height,
On the 500,the venturi seems circular,
Hope this helps
Post by: RGP750 on June 13, 2024, 06:32:43 PM
Thanks John I'll take a look at that.
