SOHC.co.uk Forums => CB750 => Topic started by: ColinHH on August 03, 2024, 03:47:38 PM
Title: K4 (US model) Fuses
Post by: ColinHH on August 03, 2024, 03:47:38 PM
I was working in the headlamp and accidentally fused the headlamp fuse. However in the fusebox it had blown the 5amp fuse which was correctly fitted where the 5amp is indicated on the box. The 7amp fuse isn’t blown. But neither the headlight or the tail light works and are therefore both being fed via the one 5amp fuse, which does’t seem correct. My understanding is that the 7 amp fuse is for the headlight and the 5amp one is for the tail light? If i just replace the 5amp fuse and leave the 7amp clips empty the headlight and tail light both work. Am I missing something or is there a problem?
Title: Re: K4 (US model) Fuses
Post by: Bryanj on August 03, 2024, 05:32:43 PM
I though it was 15, 7 and 5
Post by: ColinHH on August 03, 2024, 06:12:53 PM
Sorry, maybe I didn’t make myself clear. There are 3 fuses. 15A, 7A and 5A. The fuse that blew was the 5A which meant my headlight and tail light doesn’t work. I though the 7A was for the headlight and the 5A for tail light. But the headlight won’t work unless I put the 5A fuse in.
Post by: Bryanj on August 03, 2024, 07:23:40 PM
Then its wired wrong in the headlamp somewhere, does this have a lights on/off on the RH switch or not
Post by: ColinHH on August 03, 2024, 11:07:49 PM
Yes, it has the lights on/off on the right hand handlebar switch.
Post by: Bryanj on August 03, 2024, 11:14:55 PM
I am not that well up on the 750 variations but i know some have confusing link wires that connect different colours, you will need to closely compare your wiring to a correct model diagram
Post by: ColinHH on August 12, 2024, 05:47:31 PM
All done. There were two wires that were connected the wrong way round.
