SOHC.co.uk Forums => CB500/550 => Topic started by: SteveW on September 16, 2024, 05:09:48 PM
Title: Throttle cable routing
Post by: SteveW on September 16, 2024, 05:09:48 PM
Can someone clarify if this is correct, it seems the only way I can get it to fit nicely.
Out of throttle, around the front of the right hand fork, under clock bracket, around headstock and on the inside of left hand fork. Down the left side of the frame tube and under to the carb linkage on the right.
550 K0
Title: Re: Throttle cable routing
Post by: Seabeowner on September 16, 2024, 06:55:40 PM
I can only comment on my 500K0 when it had it's original US bars but that seems about correct. The cables change from the left side to the right above the ignition coils
Post by: SteveW on September 16, 2024, 07:28:09 PM
Should they go through the hole in the frame where the coils mount?
At the moment I have them going under the frame, below the coils?
Post by: Bryanj on September 16, 2024, 08:34:53 PM
Look in Ashs stash for the build and pdi dat its all in there
Post by: McCabe-Thiele (Ted) on September 16, 2024, 09:10:10 PM
On my 500 the throttle cables loop from the handle bars through the right side of the gap between the headlamps to the right side under the clocks straight along the right side of the frame passing on the outside of the right coil to the throttle bracket. Might not be original but a nice smooth run. I have UK bars on my 500.
Post by: SteveW on September 16, 2024, 09:14:37 PM
Think I’m going to leave mine as they are. They seem the best fit.
Just looked at 2 Honda manuals and still unsure what the correct route is, the lower image seems the best fit.
Post by: McCabe-Thiele (Ted) on September 16, 2024, 09:37:43 PM
My 500 is like the first photo, interesting printing error on the second photo where the clutch cable is called the choke cable!
If your cable action is smooth and moving the steering does not cause the revs to change then what does it matter.
Post by: SteveW on September 16, 2024, 09:39:42 PM
Cables are smooth so they are staying as they are.
Post by: Mark sharman on September 17, 2024, 10:32:20 PM
Hi Steve just seen your post I took some pictures of my 550k0 throttle cable route before I dismantled it and the two cables go through the frame frome the left hand side over the coils.i tried to attach the picks but file size is too big.if you PM me with phone or email address I can whats app or email then to you.
Post by: SteveW on September 18, 2024, 06:24:12 AM
Hi Mark,
That would be great, PM sent.
Thanks.
Post by: McCabe-Thiele (Ted) on September 18, 2024, 10:09:26 AM
This method is in Tricks & Tips to help anyone who wants help with image size.
I download my phone photos onto my laptop, upload them to Flikr then paste using the URL link process.
It could probably be all done on a phone but thats beyond my skill set.
Scroll up to the top of this page.https://www.sohc.co.uk/index.php/topic,29228.msg279879.html#msg279879
Post by: Mark sharman on September 18, 2024, 10:40:04 AM
Thanks Ted, all sounds Japanese to me. I need an interpreter LOL .My tec prowess is not great but I get there in the end.the joys of being an old git.
Post by: McCabe-Thiele (Ted) on September 18, 2024, 10:50:05 AM
It took me a while to grasp the process when I was first shown it on the Nissan 4x4 owners club site.
Now I don't even have to think about it it's become automatic at the young age if 76!
Who says OAPs aren't tech savvy.
