SOHC.co.uk Forums => CB350/400 => Topic started by: Mikep328 on October 31, 2024, 08:57:58 PM
My right side footpeg seems to regularly find itself in the vertical position so that when I start moving and try to place my foot on the peg my foot lands on "nothing." I realize that peg has to shift to allow use of the kick start lever (someday I'll have to try kickstarting to see if it actually works!).
I could drill a hole/install a removable pin to keep the peg in the riding position but wondering if anyone has experienced this and found a less invasive solution.
It should stay down on its own as its got a spring loaded bit fitted to keep it down.
Number 399 on the fiché.
[attachimg=1]
Yeah, I checked that earlier this year. The spring is there but maybe it's not quite as strong as it was in 1976! I'll try a new spring before taking any drastic action!
OR maybe I won't...DSS shows the spring not available. :(
Is the spring located correctly because if it doesn't click past the little pin , it won't stay down.
I have had the same issue with my 400 I'm roaring off from the lights with my right foot trying to land on fresh air, tricky if you need to use the rear brake.
My solution has been to put my left foot down when I stop, leaving my right foot on the rest with first gear selected and the clutch lever pulled in.
"Is the spring located correctly because if it doesn't click past the little pin , it won't stay down. "
I don't know, I'll check. I know the spring is there but I didn't examine its position
"My solution has been to put my left foot down when I stop,"
I tried that yesterday but after many, Many, MANY, years of putting my right foot down, not my left...it feels "unstable." I suppose I could get used to it. ;) But the "removable pin" is starting to sound like the best solution for someone set in their ways like me!! :)
I can't remember any of my previous bikes having a folding foot rest except at the rear.if they did they certainly were more flip resistant.
I think we have done the '400 Leg Wave' at some stage... :)
Most bikes with a kickstart lever have the footrest positioned so that the lever and footrest don't interfere with each other. Because the 400f has the footrests fairly well back the footrest has to hinge up so that you can use the kickstart lever. Not the best arrangement but it works as long as the spring locator is functional.
I've fitted lighter aluminium footrests on mine. I used a sprung ball to hold the footrest in the up position when needed, but didn't fit any locator in the normal down position. I wrongly thought that gravity and friction would keep the footrest down. ☹
The slightest contact with my leg or boot clicks the rest into the up position so I'm forever riding off with my right foot trying to push it back down again! A redesign job for the winter I think.
Just a latent point, but I was always taught, (many moons ago!!), when ready to move off, engage 1st gear, then change feet so that your right foot is ready for the brake in case of a problem. Something to peruse over the obligatory Friday night beer(sssss).
That's what I try to remember to do on the 400f but I've not made it easy for myself by having 2 bikes with gears/brakes on opposite sides! 🤣
Mike,
That spring is double leaf - one part coil inside the other - is yours double? Steve (400/4 parts) might have one. The r/h footrest on both my 400/4 and 350/4 have the correct spring and they are very positive in their action and so far have never flicked up. Think the 550F1 is the same system but not checked. I was also taught to swap feet to cover the brake after selecting the gear - IAM test in 1983!
Ian
Thanks, Ian, that's interesting! My spring is not a double leaf!!!
I think my spring has lost it's springiness. ;D ;D ;D
Mine left years ago!
You think this is a problem? Did you ever ride a 1981 Triumph Thunderbird and manage to keep your foot on the rest at all? :o
Try a 1960 Thunderbird, half the time it fell off
Now there’s a name Triumph should resurrect.
"Try a 1960 Thunderbird, half the time it fell off"
When I bought my first old British bike (1971 Norton Commando) I asked an experienced BrittBiker if I should safety-wire anything. He responded, "You only need to safety-wire the parts you want to keep! :)
And the fatal error on the 400/4 is not folding the footrest up before using the kick start resulting in a cracked kick start knuckle that renders it useless. New knuckles don't exist and finding an undamaged s/h knuckle is both very expensive and very rare.
My 60 T bird even spat the magneto slip ring out one night!
Just a thought, on the rare occasion that I watch motorcycle racing on the TV, I've always wondered why so many riders drag their right foot on the tarmac approaching a bend. I now realise that it's because most race bikes are fitted with knackered CB400F footrests and they have missed the rear brake.
Nah they are ex grass trackers used to steel boot
A bit of brain fog,
The 400/4 and 550/4 F1 are the same setup with 2 circular leaf springs, the 350/4 is different and doesn't fold, other than the slight amount provided by the torsion spring for safety.
Ian
FWIW, the 550-4 was the first four cylinder motorcycle I owned. I don't remember ever having the footpeg "accidentally" lift. Heck, I might not have even known that COULD lift - I never used a kickstarter on any of the six SOHC Hondas I owned over the years.
