SOHC.co.uk Forums => CB500/550 => Topic started by: TezzerTel on November 30, 2024, 08:52:43 AM
Looking at the cable routing diagrams in the files section it looks like the main wiring loom goes under the lower part of the triple tree/lower yoke? Is this correct?
Yes, that’s correct. There’s a cable clip positioned below the bottom yoke.
Mine has a tapping for a clip on the right hand side but the loom seems to go down the left hand side of the bike. Does the loom crossover?
Yes, indeed it does.This is to ensure there is steering ‘lock to lock’ length on the loom before it enters the headlight bowl. If you would like more piccies, I’d be happy to oblige.
Yes please more photos would help. I've clipped the brake light switch wires into the clip on the headlight bracket it seems like that's a sensible option. Also photos of the routing in around the plate where the fuse box is
More tomorrow…
There helpful thank you. I wasn't sure if the lead from the main loom that goes to the top multi plug goes over the top and down to the plug or around the lower front and up
And this…
