General => New Member Introductions => Topic started by: GT Graham on December 09, 2024, 03:25:53 PM
Hi I’m Graham
New here!
I have acquired a CB100n which I was told on purchase that it was running last year🤥.. after changing coil, rectify, points and plug, along with a new 6v battery I now have a spark, I have by past the fuel tank and have the carb set up on a separate fuel bottle.
It’s reluctant to start.
So am I thinking of checking the compression after checking the valve timing and all good it should start!..
is there anything I should be looking at before I go ahead?
This is new territory for me as I’ve always had 2 strokes
Graham
Blocked jets and passages in the carb
“Last year†is a minimum of 12 months sat with fuel in the carb. It will probably be sludge.
Thank you both..
I’ll get the carb off tomorrow and check it out… 👍
I learned to ride on a CB100 on the car park of Bedford County Council offices in 1974.
It was an RAC/ACU scheme, off road for 16 year olds. I had a Raleigh Runabout at the time.
At 17, I went for a “much more powerful†CB125S
It’s the smallest bike I’ve owned apart from my mobylettes that I’ve have had over the years! I still have my first Moby an AV76, which I built years ago..
The little Cb100 takes me back tho..
You maybe be able to answer this, were these little cb100cc any good? 😁
From what I recall, they were identical to the 125, but with 25cc less.
Had a play in the shed and have had the little cb100 running, so I know now that compression is ok, even tho I have had the carb off and cleaned it it still only runs for a minute or so, so for £31.00 and postage I can get a replacement.
I recently bought some tank cleaner off Mad for bikes, has anyone used it, it says leave in the tank for several hours and shake every 30 minutes at room temperature.
Has anyone used this product? Or should I be looking at something different?
Never tried that product and have always used DEOX-C from Bilt Hamber, excellent product and does what it says on the tin.
Thanks for that Dave
just looked it up, I will order some, plus it’s cheaper!
Graham
Plus 1 on the Deox-C.
Hello Graham
Welcome here, there's a goldmine of knowledge here to draw on too! ;D
Thanks for the welcome.. I’m sure there is a lot of knowledge here!
Welcome Graham, good to read you've had it running albeit briefly.
Thanks Ted.. a little way to go but it’s getting there
Graham
Graham
Psychologically that a good early boost to morale, be great to read your progress.
I have had a go with the tank cleaning solution from Mad for bikes, 500ml that has sat in the tank for 10 hours, it’s removed some but not all, I have ordered some DEOX-C , I’m hoping that it will get rid of the remaining rust build up.
Hopefully the photo has attached
I used the now very expensive Evaporust. My 400 tank had petrol in it that had stood for over 10 years so was pretty bad inside.
I had two distinct steps to clean the tank interior.
1. Mechanical removal of the worst of the rust and gunk inside using what was gravel & with diesel as the lubricant.
2. Wash out Diesel then add Evaporust, rotating tank as needed. Left for a couple of days. New Evaporust for final clean.
Lots of alternatives such as Citric Acid. Time consuming process
