SOHC.co.uk Forums => CB350/400 => Topic started by: Bradders on December 19, 2024, 03:53:06 PM
Title: Changing fork oil.
Post by: Bradders on December 19, 2024, 03:53:06 PM
Am going to put fresh oil in my front forks over the winter. Not done this job before. Have watched various YouTube videos and some say to take the springs out while others leave them in. What’s the best thing to do?
Also some talk about an air gap and some don’t. Do I need to do that as well?
Thanks.
Title: Re: Changing fork oil.
Post by: McCabe-Thiele (Ted) on December 19, 2024, 04:07:28 PM
When I did my 400 earlier this year the first lesson I learnt was do one side at a time.
Undo the top cap bolt, undo the drain plug, leave it to drain, I left mine overnight.
Re-fit the drain plug, ideally with a new washer, add the correct amount of oil for a top up by adding it to the top through  the center of the spring, I used a syringe.
Fit the cap back being careful not to cross thread it, tighten up, repeat on the other side. Don't worry about any air gap, it will settle down during standing or after a short couple of stops as the front forks compress.
Post by: TrickyMicky on December 19, 2024, 04:48:29 PM
My workshop manual is not to hand at present, but I seem to remember that it gave a figure for the amount of oil needed, can't remember if it was 300 or 330ml.
   I don't know if I've got this arse upwards or not, but if you brim fill the fork, as you cannot compress a liquid, what happens when the fork compresses?  Chance of popping the oil sael?
Post by: McCabe-Thiele (Ted) on December 19, 2024, 05:13:26 PM
It's 105 ml for changing fork oil, 125 ml after full strip down as per downloadable Honda Manual here.
Haynes manual shows larger quantities 145/150.
Post by: TrickyMicky on December 19, 2024, 06:14:13 PM
Well done Ted, thanks.  If it's true that confession is good for the soul, I have to admit that hundreds of years ago, when I changed my fork oil for the first ever time, I thought I would speed up the slow dribble of oil out of the drain plug. I held the front brake on and gave the handlebars a damn good downward thrust.  I never realised that such a small amount of oil could cover so much equipment on the far side of the garage!!!
     As it's supposed to be the time of good cheer, maybe a thread could be started allowing people to admit to unbelievable cock-ups they (we) have made in the past.
Post by: Bradders on December 19, 2024, 07:08:15 PM
Thanks Ted and Micky. Do I need to take the springs out at all?
Post by: McCabe-Thiele (Ted) on December 19, 2024, 07:09:30 PM
When I did my 400 fork oil change I removed both cap nuts, then  drained the oil. Consequence was both springs then pushed upwards making it much more difficult to get the first cap back on.
Post by: McCabe-Thiele (Ted) on December 19, 2024, 07:10:35 PM
No need to take the springs out, if you do for some reason make sure you put them back the right way round.
Don't ask which way round, was it the coil spacing or is that the valve springs?
Post by: Bradders on December 19, 2024, 07:22:39 PM
Thanks Ted. I will leave the springs in. Thanks for your advice.
Post by: honda-san on December 19, 2024, 07:44:54 PM
The genuine Honda shop manual needs to be read carefully as it covers both the 350/4 and 400/4.
400/4 takes 145 /150cc of oil per fork leg at oil change, 160/165cc if completely stripped (the 105 and 125 cc figures suggested previously are for the 350/4).
I have always (well, every 6000 miles over a total of 250,000) simply drained one leg at a time and re-filled with 145cc, and not worried about removing the spring nor about the air gap - just put the correct amount in.
As to which way round springs go, variable pitch springs should always be fitted with the closely spaced coils at the non-moving end. In the case of valve springs this means against the cylinder head to minimise the spring mass that is moving as the cam operates, and therefore to minimise inertia effects at very high rpm's which contribute to possible valve bounce. For fork springs it is much less important as the change in moving mass due to spring orientation pales into insignificance against the mass of the rest of the bike and rider which is going up and down. Still best practice though to fit the close coil end of the spring into the fork leg first.
FWIW, my day job for 35 years was as a design / test / calibration engineer at a company that provided consultancy services relating to spring technology.
Post by: McCabe-Thiele (Ted) on December 19, 2024, 07:52:28 PM
I can't see your figures in the Honda Manual P 51 shows 105/125 cc in the Honda manual do you have a page number that shows the higher volume?
My Haynes manual 1990 version  shows 145-150 cc
My Cycleserve manual P101 shows 145-150 cc.
Post by: honda-san on December 19, 2024, 08:06:05 PM
As I suggested, the manual does need to be read carefully as it covers both the 350/4 and 400/4.
Data specific to the 400/4 starts on page 87 in the "CB400F supplement" part of the manual.
Page 111 contains the relevant specifications. The Haynes manual is also correct in this respect as it covers only the 400/4.
Post by: K2-K6 on December 19, 2024, 08:11:09 PM
Interesting job honda-san, I'm fascinated by suspension and how it can best work.
A question though with "Still best practice though to fit the close coil end of the spring into the fork leg first." Isnt that the end that's moving with input and directly linked to the unsprung mass of wheel etc ? Therefore should be the other way up, with close coils and hence mass best placed at the sprung mass supported "static" end in top fork leg and under the cap.
Interested in views, as I've got the design of forks having damper rod bolted to fork lower casting and moving with the wheel, the top of the rod acting on the spring against the fork cap nut, or is the fork on 400 different in layout.
Agree that in this instance the variation in mass at either end is unlikely to be felt in much meaningful way.
Post by: McCabe-Thiele (Ted) on December 19, 2024, 08:15:03 PM
Thanks Chris, I'll check that out, when I drained my 400 forks there was hardly any oil in one side so I felt the benefit when I put 105ml in, I might add another 40 odd ml over this winter. That will be a 38% increase so worth the effort.
These were the answers I received in December 2023?
.http://www.sohc.co.uk/index.php/topic,30113.0.html
Post by: Laverda Dave on December 19, 2024, 10:21:58 PM
Interesting point Nigel. How would that same logic apply to a valve spring where the closed end of the spring fits closest to the cylinder head? Would you therefore say the rocker is the 'moving' unsprung end just as the front wheel would be on the front suspension in which case I see your logic. Very odd when you think about it if the closed end in the front suspension goes in first and therefore being closer would take more force to compress whereas on a valve the closed end being closest to the cylinder head is designed to reduce valve bounce.
Post by: McCabe-Thiele (Ted) on December 20, 2024, 06:20:58 AM
Thanks Chris for the manual page information that confirms the oil volume as 145-150 ml for changing the fork oil.
That's a job this winter/spring for me to top mine up to the correct level by adding another 40-45 ml to each side.
I'm not familiar with the 350 front suspension, had me wondering if it has smaller front forks, different internal design or is the difference in oil volume related to the different weight of the two models.
Every day is a schoolday. 8)
Post by: K2-K6 on December 20, 2024, 10:42:56 AM
As I understand it, the variable rate spring doesn't "see" which end is compressing it, the softest part will always move first in whichever orientation. So that doesn't matter.
In valve springs, the mass of the moving part has more importance in valve train performance and benefits any reduction available for the moving component, as honda-san notes. so completely logical in putting the higher weight of spring end at the fixed position.
In suspension, it could be speculated either way of which bit is stationary vs mobile. Suspension convention has it that the ratio of unsprung mass vs sprung mass is at advantage the lighter the unsprung is in comparison to the other.
In other words, the wheel assembly if moved lighter gives better suspension performance.  This because the ideal damping rate to control the sprung mass movement (the vehicle itself) would get more compromised if that damping rate was needed to increase for control of the unsprung mass of wheel etc. A different compromise to valve spring application.
It could be more illustrated by saying the vehicle mass is static or intended to be, with the wheels etc moving up and down to follow the road errors.  Which, if perfectly done (impossible) would give a beautiful ride. The aim of any vehicle design is to lighten the unsprung in trying to move to this scenario,  making heaviest part of spring more ideal at the fork or shock top position.
As honda-san notes though, this would be a very, very small effect. And especially so in terms of just how little difference there is from one end of the spring to the other in grams when compared to the bike components in many kilograms.
Post by: K2-K6 on December 20, 2024, 11:27:37 AM
Oil quantity isn't absolutely critical, it just has to stay reasonably abovecthe highest point that the damper valve reaches in full travel. This to avoid it causing aeration etc. Some just dip a welding rod down the centre of the spring to gauge where it sits if uncertain of what's been left in there to skew volume.
Too much though, and it'll lock the leg hydraulically against the top as the excess oil has nowhere to go if it hits the cap before full travel is complete.
A very consistent automatic transmission fluid to consider is "LT71141" specification as its a fully synthetic long life demand oil with very stable viscosity characteristics for a flat performance curve.
I do like though the Motul fork oil products, offering various viscosity range and some experiences on here for the 500 fork have been judged successful when using lower viscosity spec to get good subtle road relevant bump absorbing characteristics.
Post by: McCabe-Thiele (Ted) on December 20, 2024, 12:19:58 PM
Although I used Fork Oil a benefit of ATF's is they usually contain plasticisers to keep seals supple.
I am not familiar with LT71141 ATF, most of my automatic vehicles have been Dexron based ATF's, there is a fully synthetic Dexron 6 ATF that you can buy for under £13.00 a litre .
Post by: Bryanj on December 20, 2024, 01:45:52 PM
Originally Honda specified engine oil for forks but changed to ATF as it does not "foam" as much so damping stays more consistent.
Now companies make specific oil for forks in differeing viscosities to alter damping.
As to emptying forks we use to take the bike outside in the yard, undo both drains and pump to see how far it would go, not advisable in an encosed garage filled with your own tools, the freezer and possibly washing machine with the bosses best clothes inside!!
Post by: McCabe-Thiele (Ted) on December 20, 2024, 03:16:27 PM
One drawback with ATF is they do not show the viscosity in easy to understand units like SAE 10.
Post by: Martin6 on December 20, 2024, 11:34:48 PM
Irritatingly, there isn't a standard for fork oil viscosity. Fork oil weights can really vary between manufacturer. 40W Ohlins 1316, is the same as 15W Silkolene RSF15 fork oil.
https://motoiservices.com/en/suspension-oil-equivalence-chart/
