Other Stuff => Desperately Seeking!! => Topic started by: martin_uk on February 17, 2025, 03:29:43 PM
Title: CB500K2 four 1975 parts needed Rev counter drive cap Sorted
Post by: martin_uk on February 17, 2025, 03:29:43 PM
Continuing with my rebuild of basket case I bought and cant find the Tacho drive cap that the cable fits into on the cam cover.
If somone has one spare would be much appreciated if you could PM me.
Martin
Title: Re: CB500K2 four 1975 parts needed Rev counter drive cap
Post by: Oddjob on February 17, 2025, 03:49:05 PM
Rare and expensive as a rule when you can find one. DS still has 3 left in stock IIRC but it's bloody expensive for a small piece of alloy. https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_12451323000P
As yet it's one of the few parts not being made aftermarket, I was trying to get some made out of phosphor bronze as the alloy snaps far too easily. They would need CNC machining though and that's not always possible or cheap.
I do have a spare NOS one but I'm not sure I want to part with it, if the offer was right I suppose I would.
Post by: Bryanj on February 17, 2025, 04:16:10 PM
That DS one is a pattern part made by original company Kem(P on end of number) and it used to be dearer than that!
Post by: Oddjob on February 17, 2025, 04:32:02 PM
I thought that Bryan but it does say OEM, which is misleading.
Bloody expensive for a copy IMO.
Post by: Bryanj on February 17, 2025, 05:31:59 PM
Lot of different accurate machining in there, i wouldnt want to make one
Post by: Oddjob on February 17, 2025, 05:37:09 PM
A CNC machine should be able to do it, it's just getting all the figures right in the coding I'd imagine. Not that I can operate a CNC machine but that's the way I understand they work.
Post by: Bryanj on February 17, 2025, 07:58:38 PM
I did a small amount of cnc when i was a techician at Stroud college, took hours to work out program and if you got a number wrong you destroyed a tool
Post by: Oddjob on February 17, 2025, 08:34:34 PM
I've asked Scott (CR21) and he reckons a CNC would make them, however the cost is high for the initial outlay, it would depend on how much to make them, what to make them out of and what demand is like.
Post by: TezzerTel on February 17, 2025, 09:48:50 PM
I've got a spare if your stuck
Post by: K2-K6 on February 17, 2025, 09:53:00 PM
Thats a casting with simple finish machining, relatively cheap for the original production run facility.
Obviously more time consuming to machine from billet.
I bought a small but reasonably complex component made in stainless from billet in replacement of a car part. It's a part of central locking mechanism inside a rear hatchback central locking assembly and originally made of "pot" metal by casting. No longer available at all, fragile and vulnerable too. I heard the manufacturer of them was running cnc dental production and filling (no pun intended, oh go on then  :) ) in vacant machine time by small batch production of items like that. Unsure how true though.
Bloody amazing cnc work though, even has little "pimples" left raised from flat surface that are used for detent location within final assembly.
Post by: martin_uk on February 19, 2025, 11:01:56 AM
Thanks for feedback and offers.
I didn't realise how expensive these are, especially in current climate of falling bike prices.
Still hoping it will turn up somewhere as I have a number of project on the go and parts in many locations.
What goes wrong with them ?
Post by: Johnny4428 on February 19, 2025, 11:38:30 AM
The securing lug breakers off them because there is a design fault with either the engine casing or the drive itself. The top part of the drive that the screw attaches to engine rocker cover does not fit flat against each other in other words there is a small gap which if not filled with something will put a strain on the weakest part when the screw is tightened and SNAP. Don’t have any logical explanation why it was designed this way.
Post by: martin_uk on February 19, 2025, 11:59:13 AM
Thanks, very helpful
Post by: Johnny4428 on February 19, 2025, 12:09:59 PM
(https://uploads.tapatalk-cdn.com/20250219/797a705e100a21bafc2ecc0a178274fa.jpg)
Post by: K2-K6 on February 19, 2025, 12:32:55 PM
Something like this is ordinarily used when one component has to float with the seal arrangement here being able to accommodate that.
Did it have a dedicated bolt, with shoulder type arrangement incorporated as original ? That could be part of the design.
A little like a rear brake torque arm bolt that incorporate such arrangement to facilitate and accept movement in use, while still being tightened securely.
Post by: Oddjob on February 19, 2025, 02:48:00 PM
No, it uses a standard bolt Nigel, JIS screw IIRC.
Maybe if I get some machined I could alter the design of the flange to incorporate a small extrusion to fill that gap, would help to orientate it as well.
Just getting the drawing of the part done that the CNC machine needs to code off is expensive, so not exactly a project that you just dabble at, you either go all the way with it or give it a pass. Then of course there's the expensive of the machining and the materials, it may turn out to be more expensive than buying the copy, even though that breaks for fun, or may may turn out to be about the same, in which case only those who break them would be interested. Personally I'd fit one just for the piece of mind, nothing worse than going to change the tacho cable and finding the drive housing comes away with it, leaving you with an oil leak and no bike until you fix it. But that's just me, I tend to go overboard on trying to keep my bikes road worthy all the time.
Most breakages occur Martin because the screws rust into place, the owner needs to remove them to change the cable or to remove it for engine removal and they refuse to budge, out comes the impact driver and hey presto, the drive is in 2 pieces, sometimes you don't know until it starts weeping oil.
Post by: Johnny4428 on February 19, 2025, 02:55:33 PM
That would make sense if that was the case Nigel. Does anyone know? An original parts list might have that information.
Post by: Bryanj on February 19, 2025, 02:59:16 PM
Parts book in alladins cave mate including jdm original K0
Post by: Oddjob on February 19, 2025, 03:00:27 PM
6 x 16 JIS pan headed screw. 5x 20 JIS pan headed screw holding the cable in place.
Post by: Johnny4428 on February 19, 2025, 03:06:22 PM
Nothing to stop that lug from breaking than originally? I suppose the metal got a bit more brittle with age too.
Post by: Johnny4428 on February 19, 2025, 03:08:43 PM
The secret might have been in the length of the screw? 16mm screw would not have given a massive pressure on the lug without stripping?
