SOHC.co.uk Forums => CB750 => Topic started by: Alexandlinda on March 15, 2025, 06:26:06 PM
Title: Electrical lighting issue
Post by: Alexandlinda on March 15, 2025, 06:26:06 PM
Im hoping that there are some brighter sparks than me on here (pun intended)!
Bike is a CB750 K6 UK model.
I've just fitted a new RH handlebar switch assembly. (All 7 wires fitted correctly I think!) With the key at the first position (ignition) all the warning lights are active.  The headlight switch (H position) activates main headlight with high and low beam working but no tail light and no pilot/parking light. Brake light works. All LH switch funtions work.
 In 'P' position on the RH bar switch I get no pilot light. When I move the key to the final position I get the pilot light and the tail light.
Any thoughts on what I have missed? Any advice appeciated!
Title: Re: Electrical lighting issue
Post by: Bryanj on March 15, 2025, 07:04:56 PM
A brown and white or brown wire is not connected to the correct loom wire OR if yours has 3 fuses the tail light fuse or connectors are fubar
Post by: Nurse Julie on March 15, 2025, 07:08:36 PM
Just going to check our UK K6, I'll get back to you.
Post by: Nurse Julie on March 15, 2025, 07:12:23 PM
In 3rd position on the key, you should get tail light, pilot light and when you go to H, those 2 should still be lit up with the low and high beam. You've got a wire not connected somewhere by the sounds of it.
Post by: Alexandlinda on March 15, 2025, 10:21:55 PM
Thanks! I was guessing a disconnected wire - just cant find it! In  the headlamp shell somewhere?
Post by: Bryanj on March 15, 2025, 11:44:50 PM
Like i said brown or brown/white
Post by: McCabe-Thiele (Ted) on March 16, 2025, 09:18:04 AM
Could be just a poor connection rather than a disconnect. As we all know remote diagnosis of electrical issues is not easy.
I think it was Bryan & Mickwinf who spotted my issue on my 500. Yours is a 750 but colours will probably be the same on older Hondas..
I had parking light issues when I was fitting new bar switches, Pages 38 & 39 of this link goes into detail.https://www.sohc.co.uk/index.php/topic,28541.570.html
