SOHC.co.uk Forums => CB500/550 => Topic started by: Johnwebley on March 27, 2025, 05:30:02 PM
hi all
as the title suggests,the CB500 has charging issues,
at about 4,000rpm it produces a low charge,if I put the lights on,there is no increase,
I have checked the 3 yellow wires,all link to each other,
some time ago I fitted a RR24 combined regulator/rectifier,
could that have gone??
any ideas of what to test for?
thanks
Yes to first question but not necessarily.
There is a full charging system diagnostic system test in the Honda manual
OK
I will check it out,
the rectifier/regulator is an RR24,fitted about 10years ago,
after playing with a multi meter ,the stator and rotor have continuity,
on to Electex world web site,found a helpful page,on it is how to test the reg,
my figures are not as specified,
ordered another ,my haven't prices gone up!!!!
Make sure all your earth connections are clean and tight plus all the multiblock connectors or you may fry your new part
Ok,all terminals cleaned
I used a spray called Bulldog BDX,
a sort of deluxe version of WD40,and yes they did say it is suitable for electrical connections
Also an instruction on how to test the RR24 unit,
(https://uploads.tapatalk-cdn.com/20250330/2204a2c42f18c27b6a1f4c2b519e2301.jpg)
