SOHC.co.uk Forums => CB500/550 => Topic started by: toucheturtle on November 17, 2010, 10:17:29 AM
Title: SOHC specialists
Post by: toucheturtle on November 17, 2010, 10:17:29 AM
Hi,
Does anyone know of any reputable sohc specialists in the north west of England? I think my CB500 motor is generally pretty tired with low compression and the proverbial notchy gearbox which once warmed up doesn't like going from 1st to 2nd. I'm considering a full engine and gearbox restoration/rebuild. Phil Denton is a couple of hours away in north Wales, I've seen his adverts in the classic bike magazines. Is there anyone else in the Liverpool/Preston north west region?
Title: Re: SOHC specialists
Post by: florence on November 17, 2010, 01:52:20 PM
I found that when I took apart my original engine, it was so worn out, it was too expensive to buy all the parts to do the rebuild.  It needed a rebore, new pistons and rings, new main bearings, big ends and possibly con-rods.  It also needed a new camshaft and followers, an oil pump, cam chain and tensioners and work on the cylinder head to fix the bearing surfaces where the camshaft runs.  The only serviceable parts left were the crankcases etc.  In the end I picked up a second hand low mileage engine from an american import bike for
Post by: Bryanj on November 17, 2010, 04:07:53 PM
A lot of gearbox parts are now unobtainable so a second motor is probably the easiest way to go
Post by: matthewmosse on November 17, 2010, 05:07:12 PM
Plenty of second hand motors out there, I got a few from California Connection, I think they are called, based in matlock, Derbyshire, but they do post engines out. Cost in the region of
Post by: florence on November 18, 2010, 08:50:28 AM
...or DK can be worth a try.  They guaranteed my engine had only done 7000 miles.  I was skeptical to begin with, but when it arrived and I partly dismantled it, I was very pleased;  It was clearly almost new.
Post by: toucheturtle on November 18, 2010, 02:27:43 PM
Yeh, I know it will be an expensive job but I'm hoping if I get the job done by a reputable professional it will last me many years of happy riding.
Post by: Bryanj on November 18, 2010, 04:54:37 PM
I used to live in NW and still have relatives round Tupps Arse, or Ramsbottom to all the Southerners. I am only 2-3 hours down the M5 but like i said its the gearbox bits that aint easy. You bring it i will strip and check it and give you a list of parts needing replacement/repair and fit what you can obtain/afford
Post by: captaindonutbikes on November 18, 2010, 11:01:15 PM
bloody hell Bryan you are a nice bloke!
Post by: Bryanj on November 19, 2010, 05:02:09 AM
So the dearly beloved keeps telling me! Used to do it for a living till the dermatitis took over---now can only do bits and pieces to keep me hand in Rest of the time drive the big stuff for one of the biggest Family firms in the country---used to sell the MD his field bikes way back when his dadran the firm
