Other Stuff => Misc / Open => Topic started by: SteveW on June 01, 2025, 06:53:38 PM
Title: Tank / side panel badges fixings
Post by: SteveW on June 01, 2025, 06:53:38 PM
Does everyone rely on the standard clips to hold them on or add something like double sided tape etc?
I’ve lost one 550 four badge that was held on with just the clips.
Title: Re: Tank / side panel badges fixings
Post by: Athame57 on June 01, 2025, 09:39:40 PM
Whatever you use avoid the likes of Blue Tack, I've seen how the acid or oil that slowly seeps out over time can stain things.
Post by: SteveW on June 01, 2025, 10:12:42 PM
I was thinking of the 3M tape that you use to mount dash cam brackets on windscreens.
Post by: andy120t on June 02, 2025, 05:02:35 PM
Tiny drill bit then some lock wire or fishing wire to join the mounting pins?
