SOHC.co.uk Forums => CB500/550 => Topic started by: Gromitdog on June 26, 2025, 01:52:27 PM
Title: alternator / rotor nut removal .
Post by: Gromitdog on June 26, 2025, 01:52:27 PM
HI All DEAD QUICKY QUESTION. Honda CB550
Which way do you need to turn this nut to undo it please I had a look on the internet & it seems to be anti clockwise to undo is that correct ??? as its FT tight !!!!
Nigel
Title: Re: alternator / rotor nut removal .
Post by: Bryanj on June 26, 2025, 02:40:23 PM
1 yes its f tight
2 yes you undo anti clock(normal thread)
3 YOU NEED THE PROPER PULLER TO REMOVE THE ROTOR
Post by: DomP on June 26, 2025, 06:47:37 PM
https://ebay.us/m/56NV4H
That's what you need
Post by: Gromitdog on June 26, 2025, 09:23:48 PM
Hi Bryanj & Dom
Thank you both for your help and reply's I have got a M16 x 1.5 RH bolt as per Kens suggestion  from the local tractor store for about £2.00 so hopefully that will do the trick along with a good air compressor to undo the nut 🤞
Nigel
Post by: DomP on June 26, 2025, 09:37:27 PM
I think I stuck something in the rotor to stop it spinning
Post by: Gromitdog on June 26, 2025, 09:42:12 PM
Ok I was hoping the sharp impact of the air tool would be enough to start to undo the bolt ? But will bear in mind I might have to hold the rotor too
Post by: Laverda Dave on June 27, 2025, 08:22:55 AM
The sudden shock of the air ratchet is normally enough to loosen it. I don't think I'd be trying to hold it with my hand and be careful if you try and wedge something in there to stop it turning as you don't want it spinning and hitting the crankcase breaking a chunk off.
Post by: Bryanj on June 27, 2025, 08:36:58 AM
Long before rattle guns became cheap a ring spanner and lump hammer used to work
Post by: Gromitdog on June 27, 2025, 09:00:47 AM
Hi Laverda Dave & Bryanj
Thank you for your useful comment on where not to grab hold of duly noted...... Might be worth a little heat on the main steel lump before I attempt the air tool ? Nothing wrong with a large heavy hammer 🤗😂
Post by: Bryanj on June 27, 2025, 09:47:57 AM
Heat will make no difference, may even make the rotor expand and tighten the bolt, unless you can heat just the bolt.
The bolt is done up tight but will undo, the rotor is just on a taper with no keyway.
Have seen several rotors ruined by trying a 3 legged puller!
Post by: Gromitdog on June 27, 2025, 10:14:58 AM
Thank you for update where stick to nothing fancy just normal engineering practices 🔨 ⚒️
Post by: McCabe-Thiele (Ted) on June 27, 2025, 11:22:36 AM
Be good to read you have managed to undo it without too much palava. ;)
Post by: Gromitdog on June 27, 2025, 11:49:26 AM
Tuesday is the day for doing it. As I volunteer at a adult learning center and they have a proper  big boys compressor so should do the trick np will keep you all posted
Post by: Gromitdog on June 30, 2025, 02:17:21 PM
Well for those who where following this post Tuesday comes early up here in deepest Yorkshire, I had to drop my seat off for powder coating and I just happened to ask if Andrew had a torque gun that would undo the Stator nut and well to my surprise  after 5 seconds of the battery torque gun on it off the nut came Happy Days  :) and then pop the £2.00 puller bolt M16 x 1.5 on from the local tractor shop and off it came no problem 🤗
Jobs a good-en 🤗
Post by: DomP on June 30, 2025, 04:38:33 PM
Glad to hear it!
Post by: Gromitdog on June 30, 2025, 04:55:27 PM
Hi Bryan
I sent you some pictures via email of my choice of steering locks
Post by: Bryanj on June 30, 2025, 08:53:34 PM
Replied twice mate
